How do you change the font size on the title of a X vs Y Plot, so that
the change is seen when plotting to a printer? I have changed the
font size for the title and object text, however, only the changes
made to the object text are reflected in the printout. I also changed
object font sizes in the FILE -> Edit default preferences for the
printouts listed there. I am printing by connecting the sequence out
pin to the plot terminal on the object. I am using a HP Deskjet 1600c
printer.
Brian Mast
blmast@itt.com
printer.
Brian Mast
blmast@itt.com
