Date: Mon, 26 Jan 1998 19:17:58 +0000
Just bought HP's Data Acquisition Unit 34970 - no Vee driver found.
- does instrument has compatibility mode with the old HP 3497 ?
- any hope for HP34970 driver ?
- any hope for HP-UX driver ? The last question is more general: when
P&P drivers will be implemented on HP-UX ?
Andrew.
*** Andrzej KULIK, Ecole Polytechnique Federale de Lausanne,
*** Institut de Genie Atomique, CH-1015 LAUSANNE, SWITZERLAND.
*** Phone: (21)693'33'59, Fax: (21)693'44'70, e-mail: root@igahpse.epfl.ch
--> http://igahpse.epfl.ch/kulik.html
Andrew.
The 34970A uses a UID driver. UID drivers provide VXIplug&play driver
capability for HP HPIB instruments. The driver should be on the
CD-ROM that came with the 34970A (veedr.exe?). Install the driver and
use the "Plug&play Driver" selection from the Instrument Manager (HPIB
and VEE 4.0).
If you're using the serial port with VEE, you'll have to program the
34970A using Direct I/O and the 34970A SCPI commands.
Good luck!
Bruce Wenner
HP St. Paul
______________________________ Reply Separator _________________________________
Subject: Vrf - drier for HP34970 ?
Author: Non-HP-root (root@igahpse.epfl.ch) at HP-USA/o2=mimegw3
Date: 1/26/98 2:17 PM
Andrew.
