send q VRf-Toggle_Pin_Bitmaps vrf stimian@ara.com
to: VRf-Steve Timian
date: Tuesday, 22 April 1997 1157 MDT
> I have a number of toggle objects with unique icons. Does anyone know of a
> way to programatically set the on and off icon files for a toggle control
> object. This can be done with a picture object by adding a data input pin.
> My problem comes when the run time program is installed in a directory other
> than the exact directory which contained the icons during development.
Sir:
I don't see any control pins for doing this. However, this is a worthwhile
enhancement request and likely not difficult to implement. I will submit an
enhancement request to the VEE lab on the issue for addition in a future
version of VEE.
> Any help will be greatly appreciated.
> Thanks
> Steve
> Steven Timian
> stimian@ara.com
> (802) 763 - 8349 Ext 16 phone
> (802) 763 - 8283 fax
> Applied Research Associates
> New England Division
> RR1 Box 120A
> South Royalton, VT 05068
If you have more questions, let us know.
[<>] regards -- gvg
Sir:
version of VEE.
> Thanks
> Steve
> Steven Timian
> stimian@ara.com
> RR1 Box 120A
[<>] regards -- gvg
