send q VRf-Function_Names ww vrf peter.larsson@space.se
to: VRf-Peter Larsson
date: Sunday, 18 May 1997 1337 MDT
>From: Peter Larsson <peter.larsson@space.se>
> When Importing User Functions with the same function name, but from different
> libraries, the program can't separate them.
> The first Function loaded, overwrites the previous one.
You are doing an Import Library? All the functions are loaded into a common
pool and become part of the program if that is the case, and it is not
possible to have two functions with the same name.
According to Stan Bischof (I haven't tested this feature my own self) if you
are doing Load-Library/Unload-Library then the functions remain distinct,
set apart by the library handle in the program.
> The range of a function should not reach beyond it's own library, otherwise
> different librarys with same function names will interfer with each other.
> The problem could be solved by typing the whole path when selecting the
> function but, however, that seems like an unnecessary action or perhaps
> there is another way of solving this?
> Hope to see this feature in a near future
> We are using HP VEE 4.0 together with NT.
> /Peter Larsson
> Best Regards !
> PETER
> Peter Larsson, T/RA-PL
> Microwave Design
> Saab Ericsson Space AB, S-40515 GOTEBORG, SWEDEN
> Tel: +46-31-335 44 15
> Fax: +46-31-335 95 20
> E-mail: rapl@space.se
> http://www.combitech.se/combitspace.html
> /Peter Larsson
> Best Regards !
> PETER
> Microwave Design
