Using Vee3.12 on PC
(already have Vee4.0, but this application needs to run under
Win3.11)
The question came up to print the entire userpanel, somewhere in the
middle of program execution.
I'm able to print any sub-panel
I'm able to print the entire userpanel from the file-menu
BUT
I'm NOT able to print the entire userpanel when started with the -r
option, because the menu is not there.
When I put my entire appication in a userobject, add a print-button
to the main panel to trigger printing, it is not executed because the
program is busy with my single big userobject.
Is there any possibility, which I missed?
With kind regards,
Johannes Mulder
Philips Electron Optics tel +31 40 2766947
Building AAE-room 21 fax +31 40 2766820
P.O.B. 218
5600 MD ACHT, the Netherlands
To: hpvxd_xc@hpislsup.lvld.hp.com
Date: Tue, 20 May 1997 10:34:31 GMT+0100
Subject: Vrf: how to print entire userpanel?
Win3.11)
BUT
With kind regards,
Johannes Mulder
P.O.B. 218
