Hallo Bruce!
On Wed, 3 Dec 1997 BRUCE_WENNER@HP-USA-om22.om.hp.com wrote:
> You need to install the runtime support engine for HP VEE. It ships
> with the VEE development system. If you're running VEE 4.0, you can
> install the runtime engine on any PC as 4.0 has an unlimited run-only
> license.
> I heard that the runtime engine would be available from the VEE web
> site, but I haven't found it there. Can anybody verify this?
I think it is on
ftp://fcext3.external.hp.com/dist/mxd/pc/binfiles/veewin/index.html
Please, have a look under "VEE Run-Only".
There You can download the vr401.exe as one archive ("consolidated archive
of all files above"), or splitted in 4 pieces (vr40101.exe - vr40104.exe)
and the "hard disk setup batch file" (vr401su.bat).
> Regards,
I hope that helps.
With kind regards.
Heiko.
> Bruce Wenner
> HP St. Paul
> ______________________________ Reply Separator _________________________________
> Subject: run VEE on PC (no VEE installed)
> Author: Non-HP-Adam.Nguyen (Adam.Nguyen@PSS.Boeing.com) at HP-USA/o2=mimegw3
> Date: 12/2/97 10:24 AM
> Hello,
> Has anyone ran a "Save Secure Run Time Version" VEE program on another
> PC ( this PC has no VEE installed) ?
> If you have done that, please show me how ? OR any help will be greatly
> appreciated.
> Thank you;
> Adam D. Nguyen
> BOEING
appreciated.
Thank you;
Adam D. Nguyen
BOEING
