I'm porting a large program written originally in VEE 3.12 to VEE 4.0 under Win NT. I'm experiencing a difference in operation with the "EXECUTE RESET" command in a direct IO to an RS-232 port. It seems that in 3.12 the execute reset waited several seconds before allowing execution to proceed. In 4.0 the execute reset continues immediately and subsequent RS-232 communication is corrupted or times out.
A delay statement after the execute reset seems to solve the problem, but with a large program finding and changing all the occurrences will be time consuming. I'm also concerned about intermittent behavior if other communication over the rs-232 is similarly affected.
Also this behavior is different depending on if the functions are executed stand-alone or imported into a main program???
Does anyone know what is going on here??
Steve Morisse
MPD Technologies Inc.
"Nothing is as bad as an idea that is the only one you have.."
Albert Einstein
Steve Morisse
Albert Einstein
