David Rust <drust@doitnow.com> wrote:
> I am trying to generate a dll for VEE 4.0 and 3.12 using the Borland C++
> compiler. The examples in the HP documentation are for the MS Visual C
> compiler. I can get the library object to import the dll, but I get an
> error 'unable to load function'. Anyone been successful using the Borland
> Compiler? Any special compiler/linker commands req'd?
I don't think you'll be successful generating one dll for both, as
4.0 is 32 bit code and 3.12 is 16 bit code. Are you generating the
right # bit code for the DLL's? There should be a switch somewhere
in Borland that indicates what you are building.
COuld be all sorts of other things- but I like to check for the basics!
good luck
Stan Bischof
stanb@sr.hp.com
good luck
Stan Bischof
stanb@sr.hp.com
