Response to Mike Gustin...
Are you feeding the test limits into the sequencer via input pins?
In the ASCII specification file, does the test name correspond to the
same name in a Sequencer transaction "Test:" entry?
It sounds like you would like to load all sequencer transaction
data into the sequencer from an ASCII file? Which you cannot do.
However, you can load the test limits and you can load a list
of tests to execute (these must each have transaction entries in the
sequencer).
One way to do this is to have a sequencer with one entry which calls a
generic function and passes the test name to that function. The generic
function
sets a global with the test name, then calls a userfunction by that name
[use
a CALL box with the functionname input pin]. You would have to
manually loop through your ASCII test list passing the test name and
parameters each time, in addition you would have to collect the log
records
as they were output, each log record would have to have the name
field changed to the global test name previously set.
Sample file enclosed
[[ TEST.VEE : 3844 in TEST.VEE ]]
I went through this excersize quite some ago and it turned out to
be easier to just write my own sequencer, there were many other
features I was trying to force into the sequencer and had to
work around the outside of it to get them to work.
Let me know if this is usefull?
Thanks
Rob Marquardt
System Test Engineering
Rockwell Automation / Allen-Bradley
Milwaukee, Wisconsin, USA
Sent: Friday, April 18, 1997 11:29 AM
To: HP VEE
Subject: Vrf: Building a Log record outside of the sequencer?
Can I prebuild a log record of records at the beginning of the program
and
then use the sequencer log output to load the results?
Why do I want to do this? I will ultimately have sequencers scattered
throughout my program. I want to be able to build one log record at the
beginning of my program load my limits from an ASCII specification file
and
then have the sequencer load the result, pass, time etc. into the record.
I
would also like to use "thisTest" in the transaction sequence boxes, ie
"thisTest.LowLimit" .
My attempt at it did not work. I was reading in the test name, nominal,
high
limit and low limit in from an ASCII file and building a record using the
test name as the record name. A couple of issues arise:
1) How do you create a record of record without manually building it
throught the build record object which would be cumbersome? Obviously the
sequencer is doing it. Can I also do it earlier in the program.
2) Assuming you can build a log record identical to what comes out of the
sequencer, would the sequencer recognize it and put the information in it
correctly?
I appreciate your help
Mike Gustin
Siemens Medical Systems
mgustin@sme.siemens.com
*** uuencoded enclosure segment ***
The section below this line contains an attachment. To extract it,
copy this message to a file and use the program UUDECODE. For information
on using UUDECODE on UNIX systems, type the command 'man uudecode'. The
attachment name was originally: TEST.VEE
begin 644 test.vee
M*'-A=F5&;W)M870@(C(N,"(I"BAD871E(")-;VX@,C$O07!R+S$Y.3<@,3`Z
M,3$Z,C@@0T14(BD**'9E97)E=B`B,RXR,2(I"BAP;&%T9F]R;2`B2%`Y,#`P
M<S<P,"(I"BA3879E0T8@;FI"BAF:6QT97).04X@,"D**&-O;7!O;F5N="`P
M(%)/3U1#3TY415A4"B`H;F%M92`B56YT:71L960B*0H@*&EM<&QE;65N=&%T
M:6]N"B`@*%5S97)&=6YC=&EO;G,*("`@*&YE>'1)1"`R*0H@("`H8V]N=&5X
M="`P"@DH;F%M92`B9V5N(BD*"2AI;G1E<F9A8V4*"2`H:6YP=70@,0H)("`H
M;F%M92`B=&YA;64B*0H)("`H;W!T:6]N86P@>65S*0H)("D*"2`H;W5T<'5T
M(#$*"2`@*'1Y<&4@9&%T82D*"2`@*&YA;64@(E@B*0H)("`H;&]C:R!C;VYS
M=')A:6YT<RD*"2`@*&]P=&EO;F%L('EE<RD*"2`I"@DI"@DH:6UP;&5M96YT
M871I;VX*"2`H;&]C:V5D(&YO*0H)("AT<FEG36]D92!D96<I"@D@*&YE>'1)
M1"`T*0H)("AP;W!U<$UO=F5A8FQE*0H)("AC;VUP;VYE;G0@,"!43T=,3T)!
M3`H)("`H:6YT97)F86-E"@D@("`H:6YP=70@,0H)"2AN86UE(")$871A(BD*
M"0DH=&%G(")$871A(BD*"2`@("D*"2`@*0H)("`H:6UP;&5M96YT871I;VX*
M"2`@("AG;&]B86Q.86UE(")43D%-12(I"@D@("D*"2`I"@D@*&-O;7!O;F5N
M="`Q($-!3$P*"2`@*&YA;64@(D-A;&P@1G5N8W1I;VXB*0H)("`H:6YT97)F
M86-E"@D@("`H:6YP=70@,0H)"2AT>7!E(&-O;G1R;VPI"@D)*&YA;64@(D9U
M;F-T:6]N($YA;64B*0H)"2AT86<@(D9U;F-T:6]N($YA;64B*0H)"2AR97%U
M:7)E<PH)"2`H9&%T871Y<&4@5&5X="D*"0D@*'-H87!E(")38V%L87(B*0H)
M"2D*"0DH;&]C:R!N86UE(&-O;G-T<F%I;G1S*0H)"2AO<'1I;VYA;"!Y97,I
M"@D@("`I"@D@("`H;W5T<'5T(#$*"0DH;F%M92`B6"(I"@D)*&QO8VL@8V]N
M<W1R86EN=',I"@D)*&]P=&EO;F%L('EE<RD*"2`@("D*"2`@*0H)("`H:6UP
M;&5M96YT871I;VX*"2`@("AC86QL1G5N8R`B8F]O<"(I"@D@("`H<&%R;4UO
M9&4@(G)E=C,P(BD*"2`@*0H)("D*"2`H8V]M<&]N96YT(#(@4U1!4E0R-0H)
M("D*"2`H8V]N9FEG=7)A=&EO;@H)("`H8V]N;F5C="!$,CHP($0P.C`I"@D@
M("AC;VYN96-T($DQ.C$@1#`Z,2D*"2`@*&-O;FYE8W0@1#`Z,"!$,3HP*0H)
M("`H8V]N;F5C="!),3HQ($0Q.C$I"@D@("AC;VYN96-T($0Q.C$@3S$Z,2D*
M"2`I"@DI"@DH=FEE=T9O<B`P"@D@*&%C=&EV92!D971A:6PI"@D@*&1E=&%I
M;`H)("`H9V5O;65T<GD@-3,U(#0P,"`T-S,@,S`P*0H)("`H8V]N9FEG=7)A
M=&EO;@H)("`@*'9I97=&;W(@,`H)"2AA8W1I=F4@9&5T86EL*0H)"2AI8V]N
M"@D)*0H)"2AD971A:6P*"0D@*&=E;VUE=')Y(#@Q,"`U.#4@.3`@-3$I"@D)
M*0H)"2AT97)M:6YA;',@;VXI"@D@("`I"@D@("`H=FEE=T9O<B`Q"@D)*&%C
M=&EV92!D971A:6PI"@D)*&EC;VX*"0DI"@D)*&1E=&%I;`H)"2`H9V5O;65T
M<GD@-S@R(#<P-2`R,38@-3$I"@D)*0H)"2AT97)M:6YA;',@;VXI"@D@("`I
M"@D@("`H=FEE=T9O<B`R"@D)*&%C=&EV92!D971A:6PI"@D)*&EC;VX*"0DI
M"@D)*&1E=&%I;`H)"2`H9V5O;65T<GD@.#(V(#0Y,"`T.2`R,"D*"0DI"@D)
M*'1I=&QE(&]F9BD*"2`@("D*"2`@("AC;VYN96-T($0R.C`@1#`Z,`H)"2AP
M;VEN=',@,B`X-3`@-3$R(#@U,"`U-C0I"@D@("`I"@D@("`H8V]N;F5C="!)
M,3HQ($0P.C$*"0DH<&]I;G1S(#0@-3,U(#4U,"`W,3`@-34P(#<Q,"`V,3`@
M-S8W(#8Q,"D*"2`@("D*"2`@("AC;VYN96-T($0P.C`@1#$Z,`H)"2AP;VEN
M=',@,B`X-3`@-C,X(#@U,"`V.#0I"@D@("`I"@D@("`H8V]N;F5C="!),3HQ
M($0Q.C$*"0DH<&]I;G1S(#0@-3,U(#4U,"`V-#`@-34P(#8T,"`W,S`@-C8Y
M(#<S,"D*"2`@("D*"2`@("AC;VYN96-T($0Q.C$@3S$Z,0H)"2AP;VEN=',@
M-"`Q,#,P(#<S,"`Q,C,Y(#<S,"`Q,C,Y(#4U,"`Q,#`W(#4U,"D*"2`@("D*
M"2`@*0H)("`H<W1A8VMI;F=/<F1E<B`P(#$@,BD*"2`I"@D@*'1E<FUI;F%L
M<R!O;BD*"2D*("`@*0H@("`H8V]N=&5X="`Q"@DH;F%M92`B8F]O<"(I"@DH
M:6YT97)F86-E"@D@*&]U='!U="`Q"@D@("AT>7!E(&1A=&$I"@D@("AN86UE
M(")8(BD*"2`@*&QO8VL@8V]N<W1R86EN=',I"@D@("AO<'1I;VYA;"!Y97,I
M"@D@*0H)*0H)*&EM<&QE;65N=&%T:6]N"@D@*&QO8VME9"!N;RD*"2`H=')I
M9TUO9&4@9&5G*0H)("AN97AT240@,2D*"2`H<&]P=7!-;W9E86)L92D*"2`H
M8V]M<&]N96YT(#`@1D]2355,00H)("`H;F%M92`B<F%N9&]M*&QO=RQH:6=H
M*2(I"@D@("AI;G1E<F9A8V4*"2`@("AO=71P=70@,0H)"2AN86UE(")297-U
M;'0B*0H)"2AL;V-K(&YA;64@8V]N<W1R86EN=',I"@D@("`I"@D@("D*"2`@
M*&EM<&QE;65N=&%T:6]N"@D@("`H97AP<B`Q(")R86YD;VTH,RP@-RDB*0H)
M("`I"@D@*0H)("AC;VYF:6=U<F%T:6]N"@D@("AC;VYN96-T($0P.C$@3S$Z
M,2D*"2`I"@DI"@DH=FEE=T9O<B`Q"@D@*&%C=&EV92!D971A:6PI"@D@*&1E
M=&%I;`H)("`H9V5O;65T<GD@-#(U(#$S,"`S,#4@,S`P*0H)("`H8V]N9FEG
M=7)A=&EO;@H)("`@*'9I97=&;W(@,`H)"2AA8W1I=F4@9&5T86EL*0H)"2AI
M8V]N"@D)*0H)"2AD971A:6P*"0D@*&=E;VUE=')Y(#4R,R`R-C8@,38R(#4P
M*0H)"2D*"0DH=&5R;6EN86QS(&]N*0H)("`@*0H)("`@*&-O;FYE8W0@1#`Z
M,2!/,3HQ"@D)*'!O:6YT<R`T(#<S-R`R.3$@-S4T(#(Y,2`W-30@,C@P(#<R
M.2`R.#`I"@D@("`I"@D@("D*"2`I"@D@*'1E<FUI;F%L<R!O;BD*"2D*("`@
M*0H@("D*("`H<F5T86EN1VQO8F%L<R!915,I"B`@*&QO8VME9"!N;RD*("`H
M=')I9TUO9&4@9&5G*0H@("AN97AT240@,S`I"B`@*&-O;7!O;F5N="`P(%-%
M455%3D-%4@H@("`H:6YT97)F86-E"@DH:6YP=70@,0H)("AN86UE(")T;F%M
M92(I"@D@*&]P=&EO;F%L('EE<RD*"2D*"2AI;G!U="`R"@D@*&YA;64@(FAI
M(BD*"2`H;W!T:6]N86P@>65S*0H)*0H)*&EN<'5T(#,*"2`H;F%M92`B;&B
M*0H)("AO<'1I;VYA;"!Y97,I"@DI"@DH;W5T<'5T(#$*"2`H;F%M92`B4F5T
M=7)N(BD*"2`H=&%G(")2971U<FXB*0H)("AL;V-K(&YA;64@8V]N<W1R86EN
M=',I"@D@*&]P=&EO;F%L('EE<RD*"2D*"2AO=71P=70@,@H)("AN86UE("),
M;V<B*0H)("AT86<@(DQO9R(I"@D@*&QO8VL@;F%M92!C;VYS=')A:6YT<RD*
M"2`H;W!T:6]N86P@>65S*0H)*0H@("`I"B`@("AI;7!L96UE;G1A=&EO;@H)
M*'1R86YS86-T:6]N<R`Q"@D@(")G96X@3$]'14X@5$535$58.F=E;BAT;F%M
M92D@7'1204Y'1458.B!L;R!,12`N-2!,12!H:2!<="O9F]O(@H)*0H)*&-O
M;7!O;F5N="!L;V=F:65L9',@(FYA;64B(")P87-S(B`B<F5S=6QT(B`B;&]W
M;&EM:70B(")H:6=H;&EM:70B(")T:6UE<W1A;7`B(")D97-C<FEP=&EO;B(I
M"B`@("D*("`I"B`@*&-O;7!O;F5N="`Q($Q)5$5204Q#3TY35$%.5`H@("`H
M;F%M92`B5&5X="(I"B`@("AI;G1E<F9A8V4*"2AO=71P=70@,0H)("AN86UE
M(")497AT(BD*"2`H;&]C:R!N86UE(&-O;G-T<F%I;G1S*0H)*0H@("`I"B`@
M("AI;7!L96UE;G1A=&EO;@H)*'9A;'5E(%1E>'0*"2`H;G5M1&EM<R`Q*0H)
M("AS:7IE(#(I"@D@*&1A=&$@"@D@("!;(")B;V]P+#,L-R(@(F)O;W`L-"PV
M(B!="@D@*0H)*0H)*&EN:71686QU92!497AT"@D@*&1A=&$@("(B*0H)*0H@
M("`I"B`@*0H@("AC;VUP;VYE;G0@,3,@1D]20T]53E0*("`@*&EN=&5R9F%C
M90H)*&EN<'5T(#$*"2`H;F%M92`B0V]U;G0B*0H)("AT86<@(D-O=6YT(BD*
M"2`H<F5Q=6ER97,*"2`@*&1A=&%T>7!E($EN=#,R*0H)("`H<VAA<&4@(E-C
M86QA<B(I"@D@*0H)("AL;V-K(&-O;G-T<F%I;G1S*0H)("AO<'1I;VYA;"!Y
M97,I"@D@*&)U9F9E<B!915,I"@DI"@DH;W5T<'5T(#$*"2`H;F%M92`B0V]U
M;G0B*0H)("AL;V-K(&YA;64@8V]N<W1R86EN=',I"@DI"B`@("D*("`@*&EM
M<&QE;65N=&%T:6]N"@DH8V]U;G0@,BD*("`@*0H@("D*("`H8V]M<&]N96YT
M(#$T($9/4DU53$$*("`@*&YA;64@(G1O=%-I>F4H>"DB*0H@("`H:6YT97)F
M86-E"@DH:6YP=70@,0H)("AN86UE(")8(BD*"2`H;W!T:6]N86P@>65S*0H)
M*0H)*&]U='!U="`Q"@D@*&YA;64@(E)E<W5L="(I"@D@*&QO8VL@;F%M92!C
M;VYS=')A:6YT<RD*"2D*("`@*0H@("`H:6UP;&5M96YT871I;VX*"2AE>'!R
M(#$@(G1O=%-I>F4H>"DB*0H@("`I"B`@*0H@("AC;VUP;VYE;G0@,34@1D]2
M355,00H@("`H;F%M92`B;&ES=%MN72(I"B`@("AI;G1E<F9A8V4*"2AI;G!U
M="`Q"@D@*&YA;64@(FXB*0H)("AO<'1I;VYA;"!Y97,I"@DI"@DH:6YP=70@
M,@H)("AN86UE(")L:7-T(BD*"2`H;W!T:6]N86P@>65S*0H)*0H)*&]U='!U
M="`Q"@D@*&YA;64@(E)E<W5L="(I"@D@*&QO8VL@;F%M92!C;VYS=')A:6YT
M<RD*"2D*("`@*0H@("`H:6UP;&5M96YT871I;VX*"2AE>'!R(#$@(FQI<W1;
M;ETB*0H@("`I"B`@*0H@("AC;VUP;VYE;G0@,38@1D]2355,00H@("`H;F%M
M92`B17AT<F%C="!T97-T(&YA;64B*0H@("`H:6YT97)F86-E"@DH:6YP=70@
M,0H)("AN86UE(")!(BD*"2`H;W!T:6]N86P@>65S*0H)*0H)*&]U='!U="`Q
M"@D@*&YA;64@(E)E<W5L="(I"@D@*&QO8VL@;F%M92!C;VYS=')A:6YT<RD*
M"2D*("`@*0H@("`H:6UP;&5M96YT871I;VX*"2AE>'!R(#$@(G-T<F9R;VUT
M:')U*&$L(#`L('-T<G!O<V-H87(H82P@7"(L7"(I+3$I(BD*("`@*0H@("D*
M("`H8V]M<&]N96YT(#$W($9/4DU53$$*("`@*&YA;64@(G)E;6%I;F1E<B!O
M9B!R96-O<F0B*0H@("`H:6YT97)F86-E"@DH:6YP=70@,0H)("AN86UE(")!
M(BD*"2`H;W!T:6]N86P@>65S*0H)*0H)*&]U='!U="`Q"@D@*&YA;64@(E)E
M<W5L="(I"@D@*&QO8VL@;F%M92!C;VYS=')A:6YT<RD*"2D*("`@*0H@("`H
M:6UP;&5M96YT871I;VX*"2AE>'!R(#$@(G-T<F9R;VUT:')U*&$L('-T<G!O
M<V-H87(H82P@7"(L7"(I*S$L('-T<FQE;BAA*2DB*0H@("`I"B`@*0H@("AC
M;VUP;VYE;G0@,3@@1D]2355,00H@("`H;F%M92`B17AT<F%C="!,;W<@<W!E
M8R(I"B`@("AI;G1E<F9A8V4*"2AI;G!U="`Q"@D@*&YA;64@(D$B*0H)("AO
M<'1I;VYA;"!Y97,I"@DI"@DH;W5T<'5T(#$*"2`H;F%M92`B4F5S=6QT(BD*
M"2`H;&]C:R!N86UE(&-O;G-T<F%I;G1S*0H)*0H@("`I"B`@("AI;7!L96UE
M;G1A=&EO;@H)*&5X<'(@,2`B<W1R9G)O;71H<G4H82P@,"P@<W1R<&]S8VAA
M<BAA+"!<(BQ<(BDM,2DB*0H@("`I"B`@*0H@("AC;VUP;VYE;G0@,3D@1D]2
M355,00H@("`H;F%M92`B<F5M86EN9&5R(&]F(')E8V]R9"(I"B`@("AI;G1E
M<F9A8V4*"2AI;G!U="`Q"@D@*&YA;64@(D$B*0H)("AO<'1I;VYA;"!Y97,I
M"@DI"@DH;W5T<'5T(#$*"2`H;F%M92`B4F5S=6QT(BD*"2`H;&]C:R!N86UE
M(&-O;G-T<F%I;G1S*0H)*0H@("`I"B`@("AI;7!L96UE;G1A=&EO;@H)*&5X
M<'(@,2`B<W1R9G)O;71H<G4H82P@<W1R<&]S8VAA<BAA+"!<(BQ<(BDK,2P@
M<W1R;&5N*&$I*2(I"B`@("D*("`I"B`@*&-O;7!O;F5N="`R,2!35$%25#(U
M"B`@*0H@("AC;VUP;VYE;G0@,C0@1E)/35)%0T]21`H@("`H:6YT97)F86-E
M"@DH:6YP=70@,0H)("AN86UE(")296-O<F0@1&%T82(I"@D@*')E<75I<F5S
M"@D@("AD871A='EP92!296-O<F0I"@D@*0H)("AL;V-K(&YA;64@8V]N<W1R
M86EN=',I"@DI"@DH;W5T<'5T(#$*"2`H;F%M92`B3F%M92!,:7-T(BD*"2`H
M=&%G(").86UE($QI<W0B*0H)("AL;V-K(&YA;64@8V]N<W1R86EN=',I"@D@
M*&]P=&EO;F%L('EE<RD*"2D*"2AO=71P=70@,@H)("AN86UE(")4>7!E($QI
M<W0B*0H)("AT86<@(E1Y<&4@3&ES="(I"@D@*&QO8VL@;F%M92!C;VYS=')A
M:6YT<RD*"2`H;W!T:6]N86P@>65S*0H)*0H)*&]U='!U="`S"@D@*&YA;64@
M(F=E;B(I"@D@*'1A9R`B02(I"@D@*&QO8VL@8V]N<W1R86EN=',I"@D@*&]P
M=&EO;F%L('EE<RD*"2D*("`@*0H@("D*("`H8V]M<&]N96YT(#(U(%-%5%9!
M3%5%"B`@("AN86UE(")3970@;F%M92(I"B`@("AI;G1E<F9A8V4*"2AI;G!U
M="`Q"@D@*&YA;64@(E)E8R(I"@D@*&]P=&EO;F%L('EE<RD*"2D*"2AO=71P
M=70@,0H)("AN86UE(")296,B*0H)("AL;V-K(&-O;G-T<F%I;G1S*0H)*0H@
M("`I"B`@("AI;7!L96UE;G1A=&EO;@H)*&5X<'(Q(#$@(E)E8RY.86UE(BD*
M"2AE>'!R,B`Q(")43D%-12(I"B`@("D*("`I"B`@*&-O;7!O;F5N="`R-B!#
M3TQ,14-43U(*("`@*&EN=&5R9F%C90H)*&EN<'5T(#$*"2`H;F%M92`B1&%T
M82(I"@D@*'1A9R`B1&%T82(I"@DI"@DH:6YP=70@,@H)("AT>7!E('1R:6=G
M97(I"@D@*&YA;64@(EA%42(I"@D@*&QO8VL@;F%M92!C;VYS=')A:6YT<RD*
M"2D*"2AO=71P=70@,0H)("AN86UE(")!<G)A>2(I"@D@*'1A9R`B07)R87DB
M*0H)("AL;V-K(&-O;G-T<F%I;G1S*0H)*0H@("`I"B`@("AI;7!L96UE;G1A
M=&EO;@H)*&]U='!U=#%$($Y/*0H@("`I"B`@*0H@("AC;VUP;VYE;G0@,C<@
M3D]410H@("`H:6UP;&5M96YT871I;VX*"2AT97AT,B`X"@D@(")"96QO=R!W
M;W5L9"!B92!T:&4@97%U:79A;&5N="(*"2`@(F]F(&%N($%30TE)(&1A=&$@
M=&5S="!L:7-T(@H)("`B9FEL92XB"@D@(")T97-T(&YA;64L;&]W(&QI;6ET
M+&AI9V@@;&EM:70B"@D@(")9;W4@8V]U;&0@<&%S<R!T:&4@9&5S8W)I<'1I
M;VXB"@D@(")V:6$@=&AI<R!M971H;V0@=&]O+"!B=70@=V]U;&0B"@D@(")H
M879E('1O('-E="!T:&4@9VQO8F%L(&)E9F]R92(*"2`@(F-A;&QI;F<@=&AE
M('-E<75E;F-E<BXB"@DI"B`@("D*("`I"B`@*&-O;7!O;F5N="`R."!,04)%
M3`H@("`H;F%M92`B1&5S8W)I<'1I;VX@8V]U;&0@8F4@<V5T('1H92!S86UE
M('=A>2(I"B`@("AI;7!L96UE;G1A=&EO;@H)*&QA8F5L5F%L=64@(D1E<V-R
M:7!T:6]N(&-O=6QD(&)E('-E="!T:&4@<V%M92!W87DB*0H@("`I"B`@*0H@
M("AC;VUP;VYE;G0@,CD@3D]410H@("`H:6UP;&5M96YT871I;VX*"2AT97AT
M,B`Q,`H)("`B1F]R(&UU;'1I<&QE(&EN<W1A;F-E<R!O9B!T:&4@(@H)("`B
M<V5Q=65N8V5R(&IU<W0@8V]N8V%T96YA=&4@=&AE(@H)("`B8V]L;&5C=&]R
M(&]U='!U=',N(@H)("`B(@H)("`B1V]O9"!,=6-K(@H)("`B(@H)("`B4F]B
M($UA<G%U87)D="(*"2`@(E-Y<W1E;2!497-T($5N9VEN965R:6YG(@H)("`B
M4F]C:W=E;&P@075T;VUA=&EO;B`O($%L;&5N+4)R861L97DB"@D@(")-:6QW
M875K964L(%=I<V-O;G-I;BP@55-!(@H)*0H@("`I"B`@*0H@("AC;VYF:6=U
M<F%T:6]N"B`@("AC;VYN96-T($0R.C$@1#`Z,"D*("`@*&-O;FYE8W0@1#4Z
M,2!$,#HQ*0H@("`H8V]N;F5C="!$.#HQ($0P.C(I"B`@("AC;VYN96-T($0W
M.C$@1#`Z,RD*("`@*&-O;FYE8W0@1#DZ,"!$,CHP*0H@("`H8V]N;F5C="!$
M,SHQ($0R.C$I"B`@("AC;VYN96-T($0Q.C$@1#,Z,2D*("`@*&-O;FYE8W0@
M1#(Z,2!$-#HQ*0H@("`H8V]N;F5C="!$,3HQ($0T.C(I"B`@("AC;VYN96-T
M($0T.C$@1#4Z,2D*("`@*&-O;FYE8W0@1#0Z,2!$-CHQ*0H@("`H8V]N;F5C
M="!$-CHQ($0W.C$I"B`@("AC;VYN96-T($0V.C$@1#@Z,2D*("`@*&-O;FYE
M8W0@1#`Z,B!$,3`Z,2D*("`@*&-O;FYE8W0@1#$P.C,@1#$Q.C$I"B`@("AC
M;VYN96-T($0Q,3HQ($0Q,CHQ*0H@("`H8V]N;F5C="!$,CHP($0Q,CHR*0H@
M("D*("D*("AV:65W1F]R("TQ"B`@*&%C=&EV92!D971A:6PI"B`@*&1E=&%I
M;`H@("`H9V5O;65T<GD@,"`U,R`Q,#`R(#8W-"D*("`@*&-O;F9I9W5R871I
M;VX*"2AV:65W1F]R(#`*"2`H86-T:79E(&EC;VXI"@D@*&EC;VX*"2`@*&=E
M;VUE=')Y(#4S,2`U,C,@-S@@,S0I"@D@*0H)("AD971A:6P*"2`@*&=E;VUE
M=')Y(#0W-B`S-CD@,C4Y(#@R*0H)("D*"2`H=&5R;6EN86QS(&]N*0H)*0H)
M*'9I97=&;W(@,0H)("AA8W1I=F4@9&5T86EL*0H)("AI8V]N"@D@("AG96]M
M971R>2`Q-C(@,C@S(#,V(#$U*0H)("D*"2`H9&5T86EL"@D@("AG96]M971R
M>2`Q-B`S,3`@,C@Y(#8P*0H)("D*"2D*"2AV:65W1F]R(#$S"@D@*&%C=&EV
M92!I8V]N*0H)("AI8V]N"@D@("AG96]M971R>2`T-3(@,S$U(#<W(#4Q*0H)
M("`H:6-O;DEM86=E(")L;V]P+FEC;B(I"@D@*0H)("AD971A:6P*"2`@*&=E
M;VUE=')Y(#4Y-"`R,#4@,3$S(#,Q*0H)("D*"2D*"2AV:65W1F]R(#$T"@D@
M*&%C=&EV92!I8V]N*0H)("AI8V]N"@D@("AG96]M971R>2`S-#(@,S,S(#<W
M(#$U*0H)("D*"2`H9&5T86EL"@D@("AG96]M971R>2`U,3<@,C<U(#$P-B`S
M,2D*"2`I"@D@*'1E<FUI;F%L<R!O;BD*"2D*"2AV:65W1F]R(#$U"@D@*&%C
M=&EV92!I8V]N*0H)("AI8V]N"@D@("AG96]M971R>2`S-3@@,SDX(#0U(#(U
M*0H)("D*"2`H9&5T86EL"@D@("AG96]M971R>2`S-S`@,S$Y(#@P(#0R*0H)
M("D*"2`H=&5R;6EN86QS(&]N*0H)*0H)*'9I97=&;W(@,38*"2`H86-T:79E
M(&EC;VXI"@D@*&EC;VX*"2`@*&=E;VUE=')Y(#$S,"`T.#,@,30P(#$U*0H)
M("D*"2`H9&5T86EL"@D@("AG96]M971R>2`Q-#`@,C8U(#,P,2`S,2D*"2`I
M"@D@*'1E<FUI;F%L<R!O;BD*"2D*"2AV:65W1F]R(#$W"@D@*&%C=&EV92!I
M8V]N*0H)("AI8V]N"@D@("AG96]M971R>2`Q,C(@-30S(#$U-R`Q-2D*"2`I
M"@D@*&1E=&%I;`H)("`H9V5O;65T<GD@-30@-#`U(#,U,B`S,2D*"2`I"@D@
M*'1E<FUI;F%L<R!O;BD*"2D*"2AV:65W1F]R(#$X"@D@*&%C=&EV92!I8V]N
M*0H)("AI8V]N"@D@("AG96]M971R>2`S,30@-30S(#$S,B`Q-2D*"2`I"@D@
M*&1E=&%I;`H)("`H9V5O;65T<GD@,34P(#0Q-2`S,#$@,S$I"@D@*0H)("AT
M97)M:6YA;',@;VXI"@DI"@DH=FEE=T9O<B`Q.0H)("AA8W1I=F4@:6-O;BD*
M"2`H:6-O;@H)("`H9V5O;65T<GD@,3(R(#4Y,R`Q-3<@,34I"@D@*0H)("AD
M971A:6P*"2`@*&=E;VUE=')Y(#4T(#0U-2`S-3(@,S$I"@D@*0H)("AT97)M
M:6YA;',@;VXI"@DI"@DH=FEE=T9O<B`R,0H)("AA8W1I=F4@9&5T86EL*0H)
M("AI8V]N"@D@*0H)("AD971A:6P*"2`@*&=E;VUE=')Y(#0T-B`R-3`@-#D@
M,C`I"@D@*0H)("AT:71L92!O9F8I"@DI"@DH=FEE=T9O<B`R-`H)("AA8W1I
M=F4@:6-O;BD*"2`H:6-O;@H)("`H9V5O;65T<GD@-C0S(#4R-2`Q,30@-3$I
M"@D@("AI8V]N26UA9V4@(G5N8G5I;&0N:6-N(BD*"2`I"@D@*&1E=&%I;`H)
M("`H9V5O;65T<GD@-C8P(#,Q-2`X(#DP*0H)("D*"2`H=&5R;6EN86QS(&]N
M*0H)*0H)*'9I97=&;W(@,C4*"2`H86-T:79E(&EC;VXI"@D@*&EC;VX*"2`@
M*&=E;VUE=')Y(#<W-2`U-3,@-S$@,34I"@D@*0H)("AD971A:6P*"2`@*&=E
M;VUE=')Y(#4X-2`S,C4@,C$P(#4P*0H)("D*"2`H=&5R;6EN86QS(&]N*0H)
M*0H)*'9I97=&;W(@,C8*"2`H86-T:79E(&EC;VXI"@D@*&EC;VX*"2`@*&=E
M;VUE=')Y(#@Y,R`U-3@@-S0@,C4I"@D@*0H)("AD971A:6P*"2`@*&=E;VUE
M=')Y(#8P-"`T,#,@,3(S(#4T*0H)("D*"2`H=&5R;6EN86QS(&]N*0H)*0H)
M*'9I97=&;W(@,C<*"2`H86-T:79E(&1E=&%I;"D*"2`H:6-O;@H)("`H:6-O
M;DEM86=E(")N;W1E<&%D+FEC;B(I"@D@*0H)("AD971A:6P*"2`@*&=E;VUE
M=')Y(#$R(#$Q-R`S,S8@,38W*0H)("`H961I=&EN9R!E;F%B;&5D*0H)("D*
M"2D*"2AV:65W1F]R(#(X"@D@*&%C=&EV92!D971A:6PI"@D@*&EC;VX*"2`@
M*&=E;VUE=')Y(#`@,"`R.30@,"D*"2`I"@D@*&1E=&%I;`H)("`H9V5O;65T
M<GD@-C@P(#4Y-R`R.#`@,C<I"@D@("AJ=7-T(&PI"@D@*0H)("AT:71L92!O
M9F8I"@DI"@DH=FEE=T9O<B`R.0H)("AA8W1I=F4@9&5T86EL*0H)("AI8V]N
M"@D@("AI8V]N26UA9V4@(FYO=&5P860N:6-N(BD*"2`I"@D@*&1E=&%I;`H)
M("`H9V5O;65T<GD@-3@R(#$R-R`S-38@,C(W*0H)("`H961I=&EN9R!E;F%B
M;&5D*0H)("D*"2D*"2AC;VYN96-T($0R.C$@1#`Z,`H)("AP;VEN=',@-2`U
M,S$@,S0P(#4U,"`S-#`@-34P(#,Y,"`U-S`@,SDP(#4W,"`U,C`I"@DI"@DH
M8V]N;F5C="!$-3HQ($0P.C$*"2`H<&]I;G1S(#0@,C<R(#0Y,"`T-S`@-#DP
M(#0W,"`U,S`@-3(X(#4S,"D*"2D*"2AC;VYN96-T($0X.C$@1#`Z,@H)("AP
M;VEN=',@-"`R.#$@-C`P(#0W,"`V,#`@-#<P(#4T,"`U,C@@-30P*0H)*0H)
M*&-O;FYE8W0@1#<Z,2!$,#HS"@D@*'!O:6YT<R`R(#0T."`U-3`@-3(X(#4U
M,"D*"2D*"2AC;VYN96-T($0Y.C`@1#(Z,`H)("AP;VEN=',@-"`T-S`@,C<R
M(#0W,"`R.3`@-#DP(#(Y,"`T.3`@,S$R*0H)*0H)*&-O;FYE8W0@1#,Z,2!$
M,CHQ"@D@*'!O:6YT<R`R(#0R,2`S-#`@-#0Y(#,T,"D*"2D*"2AC;VYN96-T
M($0Q.C$@1#,Z,0H)("AP;VEN=',@,B`S,#<@,S0P(#,S.2`S-#`I"@DI"@DH
M8V]N;F5C="!$,CHQ($0T.C$*"2`H<&]I;G1S(#@@-3,Q(#,T,"`U-3`@,S0P
M(#4U,"`S.3`@-#,P(#,Y,"`T,S`@,S@P(#,U,"`S.#`@,S4P(#0P,"`S-34@
M-#`P*0H)*0H)*&-O;FYE8W0@1#$Z,2!$-#HR"@D@*'!O:6YT<R`T(#,P-R`S
M-#`@,S,P(#,T,"`S,S`@-#(P(#,U-2`T,C`I"@DI"@DH8V]N;F5C="!$-#HQ
M($0U.C$*"2`H<&]I;G1S(#8@-#`U(#0Q,"`T,S`@-#$P(#0S,"`T-C`@,3$P
M(#0V,"`Q,3`@-#DP(#$R-R`T.3`I"@DI"@DH8V]N;F5C="!$-#HQ($0V.C$*
M"2`H<&]I;G1S(#@@-#`U(#0Q,"`T,S`@-#$P(#0S,"`T-C`@,3$P(#0V,"`Q
M,3`@-#DP(#DP(#0Y,"`Y,"`U-3`@,3$Y(#4U,"D*"2D*"2AC;VYN96-T($0V
M.C$@1#<Z,0H)("AP;VEN=',@,B`R.#$@-34P(#,Q,2`U-3`I"@DI"@DH8V]N
M;F5C="!$-CHQ($0X.C$*"2`H<&]I;G1S(#8@,C@Q(#4U,"`S,#`@-34P(#,P
M,"`V,S`@,3`P(#8S,"`Q,#`@-C`P(#$Q.2`V,#`I"@DI"@DH8V]N;F5C="!$
M,#HR($0Q,#HQ"@D@*'!O:6YT<R`R(#8Q,2`U-3`@-C0P(#4U,"D*"2D*"2AC
M;VYN96-T($0Q,#HS($0Q,3HQ"@D@*'!O:6YT<R`R(#<U.2`U-C`@-S<R(#4V
M,"D*"2D*"2AC;VYN96-T($0Q,3HQ($0Q,CHQ"@D@*'!O:6YT<R`R(#@T."`U
M-C`@.#DP(#4V,"D*"2D*"2AC;VYN96-T($0R.C`@1#$R.C(*"2`H<&]I;G1S
M(#4@-#DP(#,V."`T.3`@,S@P(#@W,"`S.#`@.#<P(#4X,"`X.3`@-3@P*0H)
M*0H@("`I"B`@("AS=&%C:VEN9T]R9&5R(#$@,R`R(#0@-2`W(#D@,"`V(#@*
M"2`Q,"`Q,2`Q,B`Q,R`Q-"`Q-2D*("`I"B`@*'1I=&QE0F<@(D=R87DB*0H@
M("AT:71L949G(")";&%C:R(I"B`@*&YU;6)E<D9O<FUA=',*("`@*')E86Q&
M;W)M870@<W1A;F1A<F0I"B`@("AR96%L4VEG1&EG:71S(#0I"B`@("AR96%L
M4F%D:7A3<&5C(#0I"B`@("AI;G1E9V5R0F%S92!D96-I;6%L*0H@("D*("D*
"*0ID
end
sequencer).
function
[use
records
Thanks
Rob Marquardt
To: HP VEE
and
and
I
high
correctly?
Mike Gustin
begin 644 test.vee
"*0ID
end
Can I prebuild a log record of records at the beginning of the program and
beginning of my program load my limits from an ASCII specification file and
then have the sequencer load the result, pass, time etc. into the record. I
My attempt at it did not work. I was reading in the test name, nominal, high
correctly?
Mike Gustin
