Try inserting this statement into index.html. If you link to a directory
that contains no index.html, but the directory has read access to the world,
then you'll get a view of the directory.
<P><A HREF="http://www.ee.siue.edu/~dpaslay/turkey.htg/" ></A></P>
P.S. That's some old stuff hanging around out there on that server.
From: Curtis & Yvette Benham [mailto:benhamcy@yta.attmil.ne.jp]
Sent: Wednesday, July 07, 1999 8:58 AM
To: David Paslay
Subject: RE: Vrf-RE: VEE Web Server Configuration
Hello David,
Thank you for writing. Your suggestion would work, except that the
measurements / tests run unattended. Each cycle generates a new file - so
your suggestion would require VEE to edit the HTML file with each run to add
a new link. The web page would then increase without bound - Perhaps
there's a way to put the directory list in a list-box... I just haven't
figured that one out yet.
Curtis
Sent: Wednesday, July 07, 1999 9:22 PM
To: Benham Curtis M Civ
Cc: VRf mailing list
Subject: Vrf-RE: VEE Web Server Configuration
Importance: Low
Just edit the Index.html file in the web directory to include links to
download the files. That's the best thing about html and JavaScript, you can
find about a zillion examples on the internet, source code included.
-Dave
From: Benham Curtis M Civ [mailto:curtis.benham@yokota.af.mil]
Sent: Wednesday, July 07, 1999 3:20 AM
To: 'VEE REFLECTOR' (E-mail)
Subject: VRF: VEE Web Server Configuration
Importance: High
7 July 1999
I'm having a little problem with the VEE web server. My application
takes a series of measurements, exports the data to an EXCEL, and then saves
the file... to a web exported directory where people will be able access and
download the files... in theory. The web servers I've had experience with
to date allow a user to view the directory contents (file list) unless
"index.html" exists, or the service is explicitly denied. Does the VEE web
server have the capability to give a user a directory list (where a click on
the file-name initiates a download)? If so, how do I enable it?
Curtis
To: David Paslay
Hello David,
Curtis
Importance: Low
-Dave
Importance: High
7 July 1999
Curtis
-Dave
Importance: High
7 July 1999
Curtis
