I have a problem when changing the ActiveX interface on a server.
Background:
I'm writing an ActiveX server in Borland Builder C++ 4.0 and uses HPVEE to write a test program to test the functions in the server.
It worked fine as long as I didn't change the ActiveX interface on the server.
Problem:
After changing the ActiveX interface, I can find the new functions added in the interface via Device/ActiveX Control References. I can also initiate the object. But when I then call the new function from HPVEE I get the errror message: "ActiveX object not registered".
Does anyone have any ideas what could be wrong?
I have made a new registration of the server with the new functions.
Thank you in advance.
//Anna
> Anna Kagebeck, > F-Industriteknik
> tel 08-585 323 28
> <mailto: anna.kagebeck@ind.af.se>
Background:
Problem:
//Anna
> tel 08-585 323 28
