VEE TIME-OUT Errors:
I also use the RS232 com port alot. I am using version 3.1, but
maybe these thoughts may help:
1. In the device driver setup there is a TIME OUT parameter, maybe
this is set for a wrong amount of time. " 9600 baud is kinda
slow compared to IEEE488 "
2. The number of characters from the RS232 device can not be greater
than
the number of characters the transaction READ statement
specifies.
Even the lable data has to be accounted for.
Maybe, in your case an extra character would
signify a new read, which would not get proccessed till the
next read transaction."a half hour later"
If the "TIME OUT ERROR" appears to go away, when you sample
data at a greater speed, then this may be your problem.
This problem may also cause that mean-old "missed" or
"anomalous data" bug.
3. The "BUSS I/O monitor" can be a great help to determine when the
error
actually occurs. I have also found the logging alphanumeric
display
helpful.
Good Luck,
Karl Schmeer
SHIRE Industrial
than
specifies.
error
display
helpful.
Good Luck,
Karl Schmeer
SHIRE Industrial
