Craig,
Just a thought about your HPIB question... you have to be careful to
put the correct syntax for the command. In your example, it looks to
me like a space is missing, i.e. it should look like "FREQ:START ",A.
Usually with SCPI commands you need to separate the actual value from
the rest of the command with a space. To do that, the space must be
within the quotes.
Good luck,
Lois
______________________________ Reply Separator _________________________________
Subject: Re: HPIG syntax
Author: gvg-at-lvld (gvg@lvld.hp.com) at HP-USA,mimegw2
Date: 3/15/99 11:29 AM
Craig Schwarze wrote:
> Hi All,
> Has the syntax changed for writing commands to HP instruments via direct
> I/O...for instance, i used to be able to add a variable input to the direct
> I/O box (say A for instance), input a real constant box to it, and then
> change the transaction command to something like "FREQ:START", A...this used
> to work under VEE3, has something changed under VEE5?
Sir:
Well, no. Try putting commands through a TO STRING and inspecting them on
an ALPHANUMERIC to get an idea of exactly what you're sending to the
instrument.
[%%] gvg
> Thanks,
> Craig Schwarze
> cschwarze@optra.com
> OPTRA, Inc.
> 461 Boston St.
> Topsfield, MA 01983
> (978) 887-6600 ext. 125
> fax (978) 887-0022
Greg Goebel ftp://fcext3.external.hp.com/dist/mxd/index.html
HP MXD Marketing http://hpislsup.lvld.hp.com (HP only)
pctm@lvld.hp.com http://www.geocities.com/CapeCanaveral/Launchpad/6000
within the quotes.
Good luck,
Lois
> Hi All,
Sir:
instrument.
[%%] gvg
> Thanks,
> Craig Schwarze
> cschwarze@optra.com
> OPTRA, Inc.
> 461 Boston St.
> Topsfield, MA 01983
> fax (978) 887-0022
> Hi All,
Sir:
instrument.
[%%] gvg
> Thanks,
> Craig Schwarze
> cschwarze@optra.com
> OPTRA, Inc.
> 461 Boston St.
> Topsfield, MA 01983
> fax (978) 887-0022
