Help;
I'm working with the ActiveX Automation example datasheet.
I'm having trouble extending this example to access to header of the document.
It works for a single page document, but I need to make it multiple pages with
the same header on every page. When I moved the header information into the
header of the datasheet document, those tags can't be found any more to replace
them.
I'm a real novice with ActiveX and Word.
The syntax doesn't seem to be the same from VEE as using the macro editor in
word.
Is that true?
Does anyone know how to do this?
them.
word.
Is that true?
