I was trying to implement a sequencer transaction using functions I had
written and ran into the following problems:
Transaction: test1
Evaluate : Limit == nil
Function: do_something(arg)
If Pass : return 1
If fail call: display_error(test1.result) - Error: test1.result
My function has the characteristic of returning a nil (nothing) if the
function executes correctly, and returns an hpvee error record ( output
from the errorInfo() function), if the function fails.
When debugging his transaction I found that the sequencer object returns
the following:
Error Code 603: Type Sequencer, Variable Not Found: nil
If I Change the Evaluate to Limit == 9 ( or any other value) This
transaction returns:
Sequencer Transaction Escape: 0 , Error Code:0, Type Sequencer
Has anyone been able to get a sequencer object to operate on a nil value?
Secondly in the above example : will the Return value for the self
generated error be able to return a vee record object rather that an integer?
About the only workaround I can think of is to create a little function
that has two inputs: function and argument, contains a formula object that
builds a formula from these inputs - feeds them to a formula input pin on
another formula object, and then have the function output a 1 or 0 based on
wether the function passed or failed. These values could then be evaluated
in the sequencer transaction.
Can anyone think of a solution to this problem as well as answer my questions?
Thanks in advance
Mike Asbery
Michael Asbery
michael.asbery@nrl.navy.mil
US Naval Research Lab
(202)404-3014
Code 5733.20, 4555 Overlook Ave SW Washington DC 20375
Transaction: test1
If Pass : return 1
the following:
Thanks in advance
Mike Asbery
Michael Asbery
(202)404-3014
