vrf Adding from a File or array
Question asked by VRFuser on Oct 23, 2003
Latest reply on Oct 23, 2003 by VRFuser
Dear VEE users,
If I have a File Which was a set of data from my previous test,(for example,
I have a calibration result for a "path" of 14 different channels and now
these calibrated results should be added to my final test results... which
can be simply done by adding two from files by a formula) But my problem is
I want to calibrate the path for 14  channels but wish to make it flexible
that means if the user takes measurement for channel 1,  5 ,  and say 6 then
only calibrated values should be added for these three channels where I have
for channel 1 the calibration should be added as - 26.3412.. for ch
5 -26.3934.. and for 6 -26.37...
Is it possible to do the addition for these kind of situation from two files
? or how can I store them in an array and make this kind of addition
possible ? Can anyone help me out ? would be great full if so.
Regards
Reza Saleh
Trainee student
NOKIA BOCHUM
Germany
