Hello All,
This is what I get on my e-mail.
Can I use the attached program ?
If yes how?
If no, whats wrong with the setting?
Best regards
S. Baruch.
owner-vrf-digest@hplvlrx.lvld.hp.com (Vrf Digest) on 25-09-99 22:42:14
Please respond to vrf@hplvlrx.lvld.hp.com
To: vrf-digest@hplvlrx.lvld.hp.com
cc: (bcc: Shaul Baruch/PTT/PTC/MAS/VKI)
Subject: Vrf Digest V1 #245
Vrf Digest Saturday, September 25 1999 Volume 01 : Number 245
Date: Sat, 25 Sep 1999 15:58:19 -0400
Subject: vrf MSComm RS232 & RS485
This is a multi-part message in MIME format.
- --------------958452A8D4ACB84757411297
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
Hi folks,
Anybody that reads these messages regularly has probably seen one of
my negative comments about a few aspects of the way HPVee handles RS232.
My application actually involves collecting data from sensors on an
RS485 loop (I use an Acromag 4SCC-TTM-1 232 <-> 485 converter which is a
wonderful, trouble free device). The sensors on the loop do not have
consistent data output formats (i.e. termination characters) but their
data is always provided in bursts which allows a pause in the output to
signal completion of the data message. HPVee's serial I/O objects don't
like timeouts which makes my application more difficult than it should
be. As a result I have tried using MicroSoft's MSComm ActiveX control.
I have discovered that its not perfect but it does solve my problems. In
case some of you are having RS232 difficulties, I have attached a sample
program which shows the basics of what I have learned. It does the
following:
1) Tests for the existence of available serial ports - does not use or
require IO_Config and can tell when a port is in use by another
application.
2) Provides a menu of available ports and allows specifying the
parameters for the ports chosen (i.e. 9600,N,8,1)
3) Does what you would expect for I/O including termination character,
timeout, and max-#-of-characters input completion tests.
4) Is event driven and can therefore deal with multiple ports
simultaneously (the sample uses two).
In order to use this code you need MSComm installed and registered.
Also, it uses two ports and I'm not testing to see if you have two
available so an error will occur if you don't. I have discovered that
not all serial expansion cards are created equal; if this code does not
seem to work, consider the possibility of your hardware or its drivers
being at fault. I'm using a Comtrol RocketPort 8 port card without
problems.
My sample is probably far from perfect so if you find errors or make
improvements, please let me know. I hope this will be of help to some
of you.
Barrie Walden
WHOI, OSS
Content-Type: application/x-unknown-content-type-VEE.Program; name="MSComm.vee"
Content-Transfer-Encoding: base64
Content-Disposition: inline; filename="MSComm.vee"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