execute program
Question asked by VRFuser on Aug 11, 1999
I don't have the slightest idea.
I got that command line from the file association for .DUN files.
Perhaps you can find a way to terminate the application or reset the modem.
I bet you could kill it through one of the system dll's search through the
function reference
http://msdn.microsoft.com/isapi/msdnlib.idc?theURL=/library/sdkdoc/psdkref/a
lphafunc_64du.htm
and see if there is such a function. Let me know if you figure it out cause
that could come in handy.
Anyone else out there know how to kill an application?
-Dave
Sent: Thursday, August 12, 1999 9:16 AM
To: David Paslay
Subject: Re: execute program
thank you for your help it is much appreciated. it worked with your
command line.   i  then went to the microsoft web site to see if i could
use a similar command to terminate the connection and they said it was
impossible. i tend not to believe most things microsoft says so i was
wondering if you knew differently.
Tim Lengyel
University of Connecticut
Dept. of Civil and Environmental Engineering
