vrf Display real time
Question asked by VRFuser on Oct 12, 1999
You're right ... the control input DOES replace whatever text is in the From
File object.  I suspect that the From File object is firing before the data
is sent to the control input.  Check your data flow and make sure the new
file name is getting to the object BEFORE it fires.
If that's not the problem ... well, I don't know what to tell you...
Roger Martin
Manufacturing Engineer
email: rmartin@granville.com
phone: 303-998-4045
fax: 303-443-2546
HELIX TECHNOLOGY CORP.
Granville-Phillips
Boulder, CO USA
> -----Original Message-----
> From: Kennedy, G. Matthew [mailto:gmkennedy@Doble.com]
> Sent: Tuesday, October 12, 1999 11:51 AM
> To: 'vrf@lvld.hp.com'
> Subject: vrf Filename control question
> When using the objects
> Filename  Select------> From File.
> I am having a problem distributing HP VEE 5.01 software to a separate
> computer.  When I add the control input "Filename" to the
> "From File" object
> I notice that the old file referred to is shaded out but it
> shouldn't matter
> since that selection is now controlled by the Filename control input.
> When I attempt to run this software on a computer other than
> my own (where
> the original file that was selected existed), the software
> crashes saying
> that this file or directory does not exist.  I thought that
> by putting that
> Filename control input into the "From File" object would
> replace this..but
> the software still looks for the old shaded out file.
> What do I do!?
> G. Matthew Kennedy
> Field Engineer
> Doble Engineering Company
> Phone: 617-926-4900 x361
> Fax: 617-926-0528
> email: gmkennedy@doble.com
> This is the "vrf" maillist, managed by Majordomo.  To send messages to
> this maillist, just email to "vrf@lvld.hp.com".  Subscriptions and
> "vrf-request@lvld.hp.com".
> to "vrf-request@lvld.hp.com".
