Hello everybody,
I'm trying to use a own ActiveX function in HPVEE. When I start the program
normally I have a error "ActiveX object could not be created system error
code: 0x80040154".
When I start hpvee with Visual C++ 6.0 in the debug-mode the program runs
fine.
Does anyone have solution of this problem ?
Thanks
Claus Kuch
ConneXion Rosenberger GmbH
Pettenkoferstr. 7
85276 Pfaffenhofen (Germany)
Tel.: +49 (0) 8441 - 89381
Fax: +49 (0) 8441 - 89382
email: ckuch@corogmbh.com
http://www.corogmbh.com
code: 0x80040154".
fine.
Thanks
Claus Kuch
Pettenkoferstr. 7
the way I did it was to supply a SQL statement to access. Below is the code.
There should be no problem transposing this into a VEE formula object.
' Create permanent QueryDef.
With ManDb2
Set qdfNew = .CreateQueryDef("RepairData", _
"SELECT Failures.ProcStep, Failures.UUTType, Failures.QTY,
Failures.CauseCode, Failures.RefDes, Failures.PN, Failures.Date" _
& " FROM Failures" _
& " WHERE Failures.Date BETWEEN #" & StartDate & "# And #" & EndDate &
"#" _
& " ORDER BY Failures.ProcStep, Failures.UUTType DESC , Failures.QTY
DESC , Failures.CauseCode;")
End With
If StartDate = EndDate Then
ReportTitleString = Format(StartDate, "dddd, mmm d yyyy")
Else
ReportTitleString = "" + "=" + StartDate + " to " + EndDate + ""
Debug.Print ReportTitleString
End If
'open access to print report
ConnectAccess
With Access
.OpenCurrentDatabase DbPath & "" & Dbn
.DoCmd.OpenReport "Failure Repairs Report", acViewPreview
.Reports![Failure Repairs Report]!lblDates.Caption = ReportTitleString
.DoCmd.PrintOut , acPages, CommonDialog1.FromPage, CommonDialog1.ToPage,
, CommonDialog1.Copies
.DoCmd.Close acReport, "Failure Repairs Report", acSaveNo
End With
'delete stuff and quit access
ManDb2.QueryDefs.Delete "RepairData"
Access.CloseCurrentDatabase
Access.Quit acExit
Set Access = Nothing 'release access object
Exit Sub 'do not trample over error handler
PrintError:
If Err = 32755 Then 'error generated by commondialog cancel button
Err.Clear
Exit Sub
Else
Msg = "Error # " & Str(Err.Number) & " was generated by " _
& Err.Source & Chr(13) & Err.Description
MsgBox Msg, , "Error", Err.HelpFile, Err.HelpContext
End If
Err.Clear
End Sub
-Andrew Kronquist
----- Original Message -----
To: HP VEE Reflector (E-mail) <hpvxd_xc@hpislsup.lvld.hp.com>
Sent: Wednesday, August 18, 1999 6:12 PM
Subject: VRF: Access question
> Hi all,
> First, thanks to everyone's help on my previous questions. They really
> helped.
> Has anyone written code to print an Access 97 report from HP VEE 5.01 on
NT
> 4.0?
> Specifically, I'm having trouble generating a report that is based on a
> query. The query requires the operator to enter a batch number, which
> forces the query to return only those records that match the requested
batch
> number. What I would like to do is use HP VEE to supply that batch number
> to the query so the operator doesn't have to type it in.
> Any thoughts?
> Roger Martin
> Manufacturing Engineer
> email: rmartin@granville.com
> phone: 303-998-4045
> fax: 303-443-2546
> HELIX TECHNOLOGY CORP.
> Granville-Phillips
> Boulder, CO USA
