Barrie Waldenhello,
In HP VEE,Load Library menuitem is able to load the library file,such as custom
function, dll and etc..After defining the file name,you chose Run button.Then the
functions of the library will be listed the right of the workspace automatically.
Just try to do it.
Junguang Dai
1999.9.25
dgdai@uestc.edu.cn
99-9-22 18:17:00 you wrote
>Hello folks,
>Does anybody know how to provide an application user with a list of
>functions which become available after a library is loaded? I want the
>user to be able to chose a function for making a calculation but the
>functions available are not known at development time - they are to be
>provided later by loading a library. This means the code must load the
>library, determine what functions it contains and then present the user
>with a menu.
>Thanks in advance
>Barrie Walden
>WHOI, OSS
>This is the "vrf" maillist, managed by Majordomo. To send messages to
>this maillist, just email to "vrf@lvld.hp.com". Subscriptions and
>unsubscriptions are done through the address "vrf-request@lvld.hp.com".
>If you need details, just send a message containing the text "help"
>to "vrf-request@lvld.hp.com".
Just try to do it.
Junguang Dai
1999.9.25
dgdai@uestc.edu.cn
>Hello folks,
>with a menu.
>Thanks in advance
>Barrie Walden
>WHOI, OSS
