I don't know how to do that either. I wish I did! When I have to do a
carriage return in a direct I/O object for serial communications I send a
byte-type 13 for carriage return in a separate line after the command
string. All the lines in the Direct I/O object have the EOL turned off.
Sending a byte-type 10 for linefeed should work, too. I hope this helps.
-Andy
----- Original Message -----
From: Christian Wienhold <Christian.Wienhold@biotronik.de>
To: <hpvxd_xc@hpislsup.lvld.hp.com>
Sent: Monday, September 06, 1999 6:48 AM
Subject: VRF-line feed
> Hi All,
> I don't know how to make a line feed in a function description string.
> I tried
and
in any combination, but nothing works.
> example:
> DLLEXPORT char set_channel_desc[] ="- provides settings for
> one analog channel";
> Thank you
> Christian
> Biotronik GmbH & Co
> Woermannkehre 1
> D 12359 Berlin - Neuklln
> Tel.: +49 30 689 05 - 301
> christian.wienhold@biotronik.de
the vrf maillist, just email to:
vrf@lvld.hp.com
Subscriptions and unsubscriptions are handled through the address:
vrf-request@lvld.hp.com
to this address.
-Andy
> Hi All,
> I tried
and
> example:
> Thank you
> Christian
> Biotronik GmbH & Co
> Woermannkehre 1
vrf@lvld.hp.com
to this address.
