vrf Configuration of E2050A in HPVEE
Question asked by VRFuser on Sep 8, 1999
Lambert Smidt wrote:
> Hi all
> We have bought a LAN/HP-IB gateway E2050A and now I try
> to use it with HP-VEE
> But when I use IO/Instrument Manager/Auto Configure I always
> get The INstrument did not repond.
> My question Is there a cookbook to configure the interface in
> HP-VEE.
> I work under HPUX10.2 VEE5.0 I'm able to conect with the gateway
> by telnet and I hve made the necessary things in the SICL configuration
Hi Lambert,
I do not know if you have configured your workstation as a Lan Client. In
my WS (HP-UX 10.20, WS B180L, HP-VEE 5.0), I had to execute the following
command line:
/opt/sicl/bin/iosetup
After doing that you should be able to command an equipment with HPIB
interface connected through the LAN/HPIB gateway, but you must define this
equipment in the I/O instrument manager and specify "gateway_hostname" (as
defined in your "/etc/hosts" file) in the "gateway" option. I do not know
if there is a way to talk directly to the LAN/HPIB gateway (perhaps by
means of sockets), but I think you are more interested for controlling the
IEEE equipment.
__________________________________________________________________
Javier Real Gmez
Ingeniero Tcnico Telecomunicaciones
E-mail : jreal@mdr.indra-espacio.es
Telfono/Phone :     34-91-3963967
Fax  :     34-91-3963912
Departamento de Estaciones de Tierra / Earth Stations Department
INDRA ESPACIO (MADRID/SPAIN)
to "vrf-request@lvld.hp.com".
