Hey Allan,
That's cool! I played around with it for a few minutes and found
if you assign an ICON to the box, it wont update the title anymore
and it stays anchored. Just another suggestion to add to the rest.
Glad to hear it doesn't move in the new beta, maybe we can consider
it almost fixed...
Mike
mike.groves@ericsson.com
From: Allan Strmbert (ERA) [mailto:Allan.Strombert@era.ericsson.se]
Sent: Thursday, October 07, 1999 8:23 AM
To: 'vrf@lvld.hp.com'
Subject: vrf SET GLOBAL moving
Hi All,
I generate globals by a lot of dynamic inputs to a SET GLOBAL.
Depending on the length of the global name the SET GLOBAL box
will be pushed either to the right or to the left.
If I do not keep an eye on it before saving, it will disappear to the right
or move in over the other boxes and corrupt the program view.
One workaround is to select the global names
so the end result will position the box in
the original position.
I do not like it, a little bit too handcuffing
Properties -> Icon -> disable Show Title
will keep the box stay put
but will be like working with a blindfold.
You can see name of the box
if you take it off.
Depending on the input it will "disappear" to
the right or if left jam your program.
Anybody got an idea to make it stay put or is it a bug ?
Regards
Allan
<<SETbox.vee>>
this maillist, just email to "vrf@lvld.hp.com". Subscriptions and
to "vrf-request@lvld.hp.com".
it almost fixed...
Mike
Hi All,
if you take it off.
Regards
Allan
<<SETbox.vee>>
> Hi All,
> if you take it off.
Cute! That little guys moves around quite nicely! Looks like
a bug to me.
Workaround:
How about just opening the object- the open view doesn't seem
to move around. Turn off 'title" and "terminals" and the size is
only slightly bigger.
Stan
