This error will occur by starting and stopping a program in the development
environment that uses ActiveX automation. It occurs due to VEE's problem of
not releasing resources. If a quit() is performed correctly on the
reference, then it should not come up in the runtime environment. If you do
not want to see the error, Save as a secured runtime version, or whenever
the program abnormally terminates, close VEE and assure that no "Excel's"
are still running. What I do is after the program terminates, I click file,
and in the recent file list the one I'm working on. When it re-loads the
resources are released and I can run it again. Check the task manager to
assure it. When all the bugs are worked out, you won't have those problems
From: Michael Clavien [mailto:mclavien@comcen.com.au]
Sent: Tuesday, February 08, 2000 3:24 PM
To: Barrie Walden
Cc: 'vrf@lvld.hp.com'
Subject: Re: vrf crash
Barrie,
I did not see the original message, but I am currently experiencing similar
problem with HP Vee. It crashes on loading the program with a Red error
message telling me to quit VEE (internal error segmentation
violation(signal=11)
If I load another program first ,and then load the program I am working on,
it most time loads ok .
I am using it on a PIII 500MHz computer with a Win 98 and a DT302 card from
Data Translation. The only activeX reference is to Excel97
Barrie Walden wrote:
> Guy,
> I have this same(?) problem and I believe its caused by my use of some MS
> ActiveX objects. In my case the problem only occurs if I open the Vee
> program twice without exiting Vee. I intend to do some experimenting to
> see if I can narrow the situation down to a specific ActiveX component
> but so far I haven't had time.
> Are you using any ActiveX objects and if so, what are they?
> Barrie Walden
> WHOI
Regards
Michael Clavien
INDCONTROL Pty Ltd < POWER ELECTRONICS and CONTROLS >
294 Norton St Leichhardt 2040 Australia
this maillist, just email to "vrf@lvld.hp.com". Subscriptions and
to "vrf-request@lvld.hp.com".
To: Barrie Walden
Barrie,
> Guy,
> Barrie Walden
> WHOI
Regards
Michael Clavien
MS ActiveX objects. In my case the problem only occurs if I open the
Vee program twice without exiting Vee. I intend to do some
experimenting to see if I can narrow the situation down to a specific
ActiveX component but so far I haven't had time.
Barrie Walden
WHOI
Yes, we appear to be talking about the same problem. I still feel it's
related to the use of ActiveX objects but this is only because I didn't
experience it before incorporating them into my programs. Now it
"always" occurs. I intend to do some experimenting when I have the
opportunity.
Barrie
Michael Clavien wrote:
> Barrie,
> > Guy,
> > Barrie Walden
> > WHOI
> Guy Bonneville wrote:
> I hope somebody encountered this peroblem before.
> Every second time I open an HPVEE program that I wrote, it crashes on
> me.
> A windows error pops up and reads---
> A fatal exception 0E has occured at 0028:C0231800 in VXD VMM(0D) +
> 00001800.
> The current application will be terminated.
> Thanks in advance
> Guy
Barrie,
> Guy,
> Barrie Walden
> WHOI
Regards
Michael Clavien
