vrf How do you check a file is of the correct type?
Question asked by VRFuser on Feb 1, 2000
I am running into a problem with trying to load file data but the wrong file
was selected.  The scenario is if somebody wants to load a data file and
they select the wrong one.  Then when the record is accessed the HPVEE
program crashes because it is of the wrong type?  Is there a way that you
can check the file for the correct type while loading so the program doesn't
crash and displays a message informing the user that it is not a datafile.
Sincerely,
G. Matthew Kennedy
Field Engineer
The Doble Engineering Company
617-926-4900 x361
Fax:  617-926-0528
email: gmkennedy@doble.com <mailto:gmkennedy@doble.com>
to "vrf-request@lvld.hp.com".
