Hi All.
Does any one know the way to incoorperate HP VEE Lab with My Visual C++
program? Thanks.
Sincerely,
YawBang, LOW
Research Student
Univ. of Liverpool
Dept. Electrical Eng. and Electronics
Brownlow Hill
Liverpool L69 3GJ
United Kingdom.
email: yblow@liverpool.ac.uk
Tel (44) (0)151 794 4602
Fax. (44) (0)151 794 4540
>-----Original Message-----
>From: owner-vrf@hplvlrx.lvld.hp.com
>[mailto:owner-vrf@hplvlrx.lvld.hp.com]On Behalf Of Kiran Anand
>Sent: 03 February 2000 14:11
>To: VEE User Group
>Subject: vrf Request for help!
>Hello there,
>We have a situation where a customer needs to calibrate HP 8991A Peak Power
>Analyser & this includes Measurement of Instrumentation Uncertainty. The
>customer is referring to Calibration guide Part no. 08991-90023 - Page-1-12
>to 1-17. The software (on Floppy disk part no. 08991-10003) provided
>along-with the manual to run the above-mentioned Instrumentation
>uncertainty
>test, needs to be run on a HP 9000 series 200/300 Computer. All other
>equipment needed to run this test is available with the customer & is stuck
>only at this position being unable to run this program which is in
>LIF-format Floppy.
>1. As the HP 9000 series 200/300 computer is obsolete how can the customer
>view & run the program provided on the diskette. This software
>also needs HP
>BASIC to be running on the computer.
>2. Is the same test program available in WIN95 or DOS format. Can the same
>program be run on any Win95-based computer & would HP-BASIC for Windows be
>required. If yes, pls send the software to me as e-mail attachment.
>3. The customer has HP VEE 5.0 with HP 82341C HP-IB Interface card. Can we
>load the above test program into VEE & run the same from VEE as
>VEE supports
>HP-BASIC.
>I look forward to any assistance from the group.
>Thanks & Best regards,
>Kiran Anand
>Customer Engineer
>TMI Support.
>Emitac Ltd., P.O. Box-8391,
>Block-B, Arenco Bldg.,
>Zabeel Road, Dubai, UAE.
>Ph: 971-4-3377591
>Fax: 971-4-3370899
>E-mail: kiran_anand@emitac.co.ae
>Web: www.emitac-ae.com
>This is the "vrf" maillist, managed by Majordomo. To send messages to
>this maillist, just email to "vrf@lvld.hp.com". Subscriptions and
>unsubscriptions are done through the address "vrf-request@lvld.hp.com".
>If you need details, just send a message containing the text "help"
>to "vrf-request@lvld.hp.com".
program? Thanks.
Sincerely,
YawBang, LOW
Research Student
Univ. of Liverpool
Brownlow Hill
Liverpool L69 3GJ
United Kingdom.
>To: VEE User Group
>Hello there,
>uncertainty
>LIF-format Floppy.
>also needs HP
>VEE supports
>HP-BASIC.
>Kiran Anand
>Customer Engineer
>TMI Support.
>Ph: 971-4-3377591
>Fax: 971-4-3370899
