Scott,
Why not use a Declare variable - record and set your sizes and types
there. Then read your records into this temp variable and output the value
of the temp variable. This output will have the result of always having
the same size.
Mike Asbery
At 11:40 AM 2/28/2000 -0600, Anderson, Scott wrote:
> Opp's wrong example in the last mail.
> sorry
> > Hello all
> > I am reading multiple records and am trying to default them all to the
> same size and shape.
> > attached is the example of what I am trying to do with more of an
> explanation.
> > thanks for your help
> > Scott Anderson
> > Process Development
> > ADC
> > BCG Wireless
> > 1100 N 4th St.
> > LeSueur, MN 56058
> > 1-800-366-3889 EXT.4784
> > scott_anderson@adc.com
Michael N. Asbery, NRL Code 5733.20, (202)404-3014, DSN 357
michael.asbery@nrl.navy.mil fax (202)404-7661
this maillist, just email to "vrf@lvld.hp.com". Subscriptions and
to "vrf-request@lvld.hp.com".
the same size.
Mike Asbery
> sorry
> > Hello all
> explanation.
> > Scott Anderson
> > Process Development
> > ADC
> > BCG Wireless
> > 1100 N 4th St.
> > LeSueur, MN 56058
sorry
> Hello all
> I am reading multiple records and am trying to default them all to the same size and shape.
> attached is the example of what I am trying to do with more of an explanation.
> Scott Anderson
> Process Development
> ADC
> BCG Wireless
> 1100 N 4th St.
> LeSueur, MN 56058
