Jeff,
Below is a document I had written a couple of years ago discussing this very
topic. In the Win95/NT environment you can create a batch file that contains
the appropriate login and FTP commands and execute ftp with a -s option to
specify a script file to run. I have not tested this in Windows 98 or 2000, but
I would expect Microsoft keeping the same command line options for the ftp
program.
Hope this helps,
Lyle Carnahan
Agilent Technologies
lyle_carnahan@agilent.com
Type: Technicalnote
Situation:
Using FTP within HP VEE environment on a PC to transfer files
to/from remote server.
Solution:
This document describes the process of using FTP to transfer files
to remote servers from the HP VEE graphical user environment. This
is useful when transferring data files collected from instrumentation
to remote servers for backup purposes.
The following example was created with HP VEE 4.0 on PC running
Windows 95. The program is also tested under Windows NT 4.0 and
should work with other versions of VEE and Windows NT as well.
Since FTP is an interactive program and usually requires user
interaction to work, FTP requires use of a script file to auto
login to the remote server. A simple script file would have the
following format:
open hpislsup.lvld.hp.com
anonymous
lylec@m2490dmc.nsr.hp.com
quit
This entry would open an anonymous FTP connection to
hpislsup.lvld.hp.com server with my e-mail address as the password.
The connection would then be immediately terminated with the quit
command.
To use this method within the HP VEE environment to automatically
perform the FTP transactions, there are two methods that can be used.
The first method would be used when the same procedure, files, and
commands would be performed for every transaction to a specific server.
The second method would be to have VEE create the script file
programmatically. The two methods will be outlined below.
Method 1:
Filename: C:FTPSCRIPTSCRIPT1.SCR
Contents:
anonymous
lylec@m2476s3m.nsr.hp.com
cd pub/pc/
get services.txt
quit
Method 2:
| To File: C:FTPSCRIPTSCRIPT1.SCR |
| X Clear File At PreRun & Open |
| WRITE TEXT "open hpislsup.lvld.hp.com" EOL |
| WRITE TEXT "anonymous" EOL |
| WRITE TEXT "lylec@m2476s3m.nsr.hp.com" EOL |
| WRITE TEXT "cd pub/pc/" EOL |
| WRITE TEXT "get services.txt" EOL |
| WRITE TEXT "quit" EOL |
|_____________________________________________|
Both methods will perform the same functions. They open the
connection to hpislsup.lvld.hp.com, login as anonymous with password
lylec@m2490dmc.nsr.hp.com, change directories to pub/pc, and download
the file services.txt into the local current directory.
In addition to the above file, an EXECUTE PROGRAM (PC) will need to
be called to initiate the FTP connection. Both methods will use the
same object within VEE as the script is only a file on the harddrive.
The execute program will have the following format.
| Run Style: Normal |
| Wait for prog exit: Yes |
| Prog with params: ftp -s:script1.scr |
| Working directory: C:FTPSCRIPT |
The -s: option of the ftp specifies to use the named script as
the ftp commands. A window will appear for a brief amount of time
and execute the commands in the script file. The ftp program comes
standard with the operating system for Windows 95 and NT.
Using the standard set of FTP commands, the local current
directory (LCD) could be changed, multiple files (MGET) could be
retrieved, and transfer mode could be changed to BINARY. Inputs
could also be added to the VEE object to specify commands and/or
parameters programmatically.
Revision 1.0 17 Sept 97 lec
________________________________________________________________________
Copyright Hewlett-Packard Co. 1996
This information is subject to change without notice and is provided
"as is" with no warranty. Hewlett-Packard shall not be liable for
any direct, indirect, special, incidental or consequential damages
in connection with the use of this material.
From: Jeff.Davis@motorola.com [mailto:Jeff.Davis@motorola.com]
Sent: Wednesday, February 16, 2000 8:00 AM
To: vrf@lvld.hp.com
Subject: FW: vrf - FTP help?
Question:
I am trying to take upload files to from my Windows NT client to my
webserver that is a Unix machine. I have an account on the Unix machine
with the proper permissions. What I would like to know is if anyone out
there can tell me how to use VEE to access this webserver and then transfer
a file(s) from my Client to the Unix account. I use Cute FTP, or WS_FTP to
do this via Windows. I am pretty sure that we can do the same thing with
the commandline version of telnet and a batch file, but would like some
advice or suggestions.
Thanks in advance,
Jeff Davis
Motorola SSTG
8201 E. McDowell Road
Scottsdale, AZ 85257
PH: 480-441-2178 FAX: 480-441-2617
CELL: 602-316-6121 PAGER: 602-201-5449
this maillist, just email to "vrf@lvld.hp.com". Subscriptions and
to "vrf-request@lvld.hp.com".
