Hi Jeff
Try this for WIN NT in command window
C:>ipconfig > filename.txt
C:>ipconfig /all > filename.txt
C:
et name > filename.txt
C:
et ?
then you can read filename.txt from VEE etc.
> pipe to
>> append to
To see date and time use EVENT VIEWER but I do not no how to
get it into VEE.
Regards
Allan
From: Davis JeffTEF-P25691 [mailto:Jeff.Davis@motorola.com]
Sent: Monday, February 07, 2000 8:34 PM
To: vrf@lvld.hp.com
Subject: vrf How can I get the following data out of NT?
Help?
We are using VEE 5.01 on Windows NT 4.0 Workstations. We would like to be
able to go out and get the following data:
1. User Name of whoever is logged in.
2. Date and Time that they logged in.
Also, what other parameters can we get from the OS, like IP addresses? Any
help would be appreciated.
Jeff Davis
Motorola SSTG
Scottsdale, AZ
this maillist, just email to "vrf@lvld.hp.com". Subscriptions and
to "vrf-request@lvld.hp.com".
C:
C:
et ?
> pipe to
>> append to
get it into VEE.
Regards
Allan
To: vrf@lvld.hp.com
Help?
Jeff Davis
Motorola SSTG
Scottsdale, AZ
