Mike,
If you turn on "show execution flow" the problem will surface. The first
time you run the program the 2nd for count actually executes. Put a logging
alphanumeric onto the output pin of the 2nd alphanumeric. You will now find
that it takes considerably longer to execute the 2nd for count.
Richard A. Walker Mailto: rwalker@mpd.com
Test Engineer
MPD Technologies Inc.
49 Wireless Blvd http://www.mpd.com
Hauppauge, NY 11788
(631) 231-1400 x462
(631) 237-9800 Fax
(631) 434-1725 Fax alternate
[mailto:owner-vrf@hplvlrx.lvld.hp.com] On Behalf Of Mike Groves (EUS)
Sent: Friday, March 17, 2000 9:12 PM
To: vrf@lvld.hp.com
Subject: vrf Time to Ask someone
Hi guys,
I have an interesting problem with getting VEE to execute a loop
with any kind of speed. I KNOW it can do it, because I can force
it to go more than 10x faster (see Text Box in program). But how
do I keep it fast all the time???
This is one bug that really BUGS me. Run my little program and
and see if you get a 10:1 speed ratio like I get, depending only
on where you clicked last. BTW, I run VEE 5.01 on a PIII/550
under NT4 SP5.
Sorry to be so vague, but it's easier to show than explain.
Mike Groves
Ericsson Inc.
mike.groves@ericsson.com
Test Engineer
Hauppauge, NY 11788
(631) 231-1400 x462
(631) 237-9800 Fax
To: vrf@lvld.hp.com
Hi guys,
under NT4 SP5.
Mike Groves
Ericsson Inc.
