Markus,
As David Paslay said, you probably want to use FromString here.
However, VEE should never terminate like this, it should error nicely. This
has been submitted to our bug tracking database and will be fixed in the
next Beta release of VEE 6.
Thanks for the bug report!
Sue Wolber
Agilent VEE Team
From: Markus Bernhardt [mailto:bernhardt@somatec.de]
Sent: Tuesday, November 30, 1999 7:02 AM
To: VEE Usergroup (E-Mail)
Subject: vrf : error output terminal bug?
Hi all,
in our actual project we have a nice behaviour of HP VEE 5.01 with NT 4 SP
5.
We want to calculate the values from a peak power meter and show them in a
graphic.
The data values y were wrong formatted and given to the formula object to
calculate the
amplitudes. The formula object has an error output terminal to catch
possible errors.
The formula object causes VEE to terminate without any message.
<<failure.vee>>
Can someone tell me what happens?
Regards
M. Bernhardt
Somatec B. Aufenanger & M. Bernhardt
Jagdweg 7a
D-82041 Deisenhofen
Telefon : (089) 613 984 94
Fax : (089) 613 981 23
Email : Bernhardt@somatec.de
homepage : http://www.somatec.com
this maillist, just email to "vrf@lvld.hp.com". Subscriptions and
to "vrf-request@lvld.hp.com".
Sue Wolber
Agilent VEE Team
Hi all,
5.
graphic.
calculate the
possible errors.
<<failure.vee>>
Regards
M. Bernhardt
Jagdweg 7a
D-82041 Deisenhofen
