Hi All.
[Redirecting standard output without using a file]
> Oh. Well, yes, but it's a pain.
Yeah, well it's more of a pain than I realized at first. Memory mapped files
won't do it -- one has to use anonymous pipes. All the simple methods I've
tried have failed so this is now delegated to a Sunday morning project. As
long as I can find a method that works before kick-off I'll post it for
y'all Monday.
Shawn Fessenden
Mgr., Technical Support
Oswego Software, Inc.
mailto:shawn@oswegosw.com
http://www.oswegosw.com
this maillist, just email to "vrf@lvld.hp.com". Subscriptions and
to "vrf-request@lvld.hp.com".
y'all Monday.
Shawn Fessenden
Is there a way to redirect text, generated by a DOS command, from the
screen to a VEE application?
ie, if I use the DOS command "ping", I get an output to the screen. I
would like to use this info in an application without redirecting to a
text
file (>filename.txt), then reading into the application.
Thanx
Iain Hamilton
