> From: Anderson, Scott [mailto:Scott_Anderson@adc.com]
> Sent: Thursday, February 17, 2000 11:33 AM
> To: 'vrf@lvld.hp.com'
> Subject: vrf VRF - Printing Ideas?
> Hello all,
> Attached is a .PDF file of a way we have to print labels.
> Right now we run the label through the LaserJet printer to
> place the graph (with data points) onto the labels.
> (Unfortunately we use Labview for this)
> Then we run the labels back through for the barcodes and text
> using LabelView.
> I am able to print the graphs with hpvee but the barcodes
> going vertically is a problem.
> If any one has a suggestion please let me know.
> <<Examples.pdf>>
> Thanks,
> Scott Anderson
> Process Development
> ADC Telecommunications
> BCG Wireless
> 1100 N 4th St.
> LeSueur, MN 56058
> 1-800-366-3889 EXT.4784
> scott_anderson@adc.com
Hi Scott,
I know little about barcodes, but I have a Sep-10-1998 note that Bruce
Wenner said:
Multiple ActiveX Barcode Controls: WWW to http://www.download.com Quick
Search on "barcode".
Hope this helps!
| Ted Cline
| PC Test & Measurement Support
| Measurement Connectivity Operation (MCO)
| Agilent Technologies
| CU-328, 815 14th Street SW, P.O. Box 301, Loveland, CO 80537 USA
| 800-452-4844 Customer Support (United States)
| 877-894-4414 Customer Support (Canada)
| 970-679-5260 FAX
| ted_cline@agilent.com
| pctm@lvld.hp.com
| ftp://fcext3.external.hp.com/dist/mxd/index.html Postsales Support
this maillist, just email to "vrf@lvld.hp.com". Subscriptions and
to "vrf-request@lvld.hp.com".
