Rolf is right on for the workarounds he listed. FYI this bug has already
been fixed in VEE 6. Check out the VEE 6 Beta program (link at
http://www.agilent.com/find/vee ) for cool stuff coming in the next version!
Sue Wolber
Agilent VEE Team
From: Heilman, Douglas [mailto:heilmand@tycoelectronics.com]
Sent: Tuesday, February 08, 2000 9:24 AM
To: 'Rolf.Neumann@infineon.com'; vrf@lvld.hp.com
Subject: RE: vrf RE HELP SET VARIABLE NAME
Rolf, The first work around helps considerably but the second seems to
erase the "hour glass" effect completely. Thanks for the help.
Doug Heilman heilmand@tycoelectronics.com
> From: Rolf.Neumann@infineon.com [SMTP:Rolf.Neumann@infineon.com]
> Sent: Tuesday, February 08, 2000 8:22 AM
> To: vrf@lvld.hp.com
> Subject: AW: vrf RE HELP SET VARIABLE NAME
> I think there are two possible solutions(=get arounds) to this
> behaviour :
> 1.) double klick on the SET VARIABLE Object and leave it in this view
> (so that you can see the terminals of this object)
> or
> 2.) disable the show title option in the property-menue of the SET
> VARIABLE Object
> (Properties-->Icon-Tab-->ShowTitle)
> Rolf
> > Sent: Tuesday, February 08, 2000 6:51 AM
> > To: 'Ferrari Maurizio'; 'VRF'
> > Maurizio, This does not appear to help very much. There is something
> > very strange going on here. The "hour glass" effect does not appear to
> be
> > related strongly to the length of the two variable names. I tried "X"
> and
> > "Y" for the two variable names rather than "LoooooooooooooooongName" and
> > "ShortName" and there was no significant change in the timing. Your
> > change of pinging the Set Variable object and the constant integer
> object
> > speed up the code slightly but the "hour glass" effect does not go away.
> > From: Ferrari Maurizio [SMTP:Maurizio.Ferrari@cselt.it]
> > Sent: Tuesday, February 08, 2000 3:52 AM
> > To: 'VEETEST REFLECTOR LIST'
> > Subject: vrf RE HELP SET VARIABLE NAME
> > Importance: High
> > This should be the correct way to set the variable name
> > <<set variable name.vee>>
> > Bye
> > Maurizio Ferrari
> > C.S.E.L.T.
> > Centro Studi e Laboratori Telecomunicazioni S.p.A.
> > Via G. Reiss Romoli 274 - 10148 Torino
> > Tel. 011 2287446
> > E-mail : Maurizio.Ferrari@cselt.it
> > << File: set variable name.vee >>
> This is the "vrf" maillist, managed by Majordomo. To send messages to
> this maillist, just email to "vrf@lvld.hp.com". Subscriptions and
> unsubscriptions are done through the address "vrf-request@lvld.hp.com".
> to "vrf-request@lvld.hp.com".
Sue Wolber
Agilent VEE Team
> To: vrf@lvld.hp.com
> behaviour :
> or
> VARIABLE Object
> Rolf
> be
> and
> object
> > Importance: High
> > Bye
> > Maurizio Ferrari
> > C.S.E.L.T.
> > Tel. 011 2287446
Is there a way to uncheck ALL the 'Show Terminals Check Boxes' for all
objects programmatically rather than one at a time?
Mark Goldberg
Tecom Industries, Inc.
9324 Topanga Canyon Blvd.
Chatsworth, CA 91311-5795
mailto:mgoldberg@tecom-ind.com
Phone 818-341-4010 x-347
Fax 818-341-1589
http://www.tecom-ind.com
