I am using HPVEE 3.01 to communicate to a serial device, thru a
terminal server. For writing/reading to the terminal server, i am using
'To/From Socket' object. Sometimes while writing to the Terminal server
, it gives error code 920. The explanation of the error code says--
Write on a pipe with no process to read it (signal= <n>
this error i get sometimeonly. if i run the program again, it runs fine.
Has anyone come acrooss anything like this..or can you suggest me
the possible solution.
Thanking you in advance.
mir
mmahiuddin@hns.com
tel - 301-548-1933
mir
mmahiuddin@hns.com
tel - 301-548-1933
