VRf : Re-convert User Functions
Question asked by VRFuser on Aug 6, 1997
I have seen the following behaviour:
     Make a user object.  Then select make user function.  You get a user
     function.  Now I want to UN-MAKE the function, (like un-pack) to get
     back to a user object, but when I select Make user-object I get a User
     object -around- the user function, rather than an un-packed user
     function.  That is, I would like the user function to turn back into a
     user object.    Martin, is that your situation as well?
______________________________ Reply Separator _________________________________
Subject: Re: VRf : Re-convert User Functions
Author:  gvg-at-lvld (gvg@hpislsup.lvld.hp.com) at HP-Sonoma,shargw1
Date:    7/30/97 7:11 AM
      website:  ftp://fcext3.external.hp.com/dist/mxd/index.html
to:   VRf-Martin Wrede
date: Wednesday, 30 July 1997 0811 MDT
> Hello VEE designers,
> page 4-3 of the "HP VEE Advanced Programming Techniques" tells how to convert
> between User Objects and User Functions.
> When following the procedure given in the manual for HP VEE 4.01 under
> Windows NT, it turned out to be rather unidirectional. Making a User Function
> from a User Object seems to be possible, but not the other way round.
Sir:
It seems to work as advertised:  if you go to the UserFunction object menu
and select Make UserObject, you get a UserObject.
> Are there any comments, suggestions, workarounds ?
>    _/ _/ _/  Martin Wrede
>   _/ _/ _/
>  _/ _/ _/    Ericsson Eurolab Deutschland GmbH
> _/ _/ _/     Hildesheim - Germany
> Email: eedmawr@eede.ericsson.se
If you have more questions, let us know.
[<>] regards -- gvg
