Stan,
You are right that you can't use *Instrument* I/O, but you can use other
I/O. In particular, you can use To/From socket to talk to the instrument.
In fact, if you're talking to an 871XC, this capability should be in the
instrument's web page help. I spoke with one of the designers and he
put the information in.
Mark Ahrens
US TMO Call Center
>To: hpvxd_xc@hpislsup.lvld.hp.com
>Subject: VRF - LAN Instrument
>Content-Type: text/plain
>Status: RO
>Hi
>Here's a new wrinkle (at least new to me). I have an instrument with
>a LAN interface, such that one can telnet directly to the instrument
>and without logging on issue SCPI commands and receive responses.
>And of course I am looking at how to talk to this using VEE.
>As far as I understand I can't use Instrument I/O at all since it's
>not a gateway - no HPIB or serial or the like but rather a direct LAN
>connection.
>If I was in Unix I'd exopect to be able to use an "Execute Program"
>then read/write command via stdio. However I'm here on a PC, so
>stdio doesn't exist, and so the "execute program" object doesn't
>do transactions.
>Short of writing some sort of external program to act as
>an intermediary, are there any suggestions?
>So far as I can tell the only services available are telnet and ftp.
>This beast can generate X displays to a remote server, has on-line help
>via the display, etc.
>It has HPIB interface but I'd like to talk via the LAN connection.
>thanks
>Stan Bischof
>stanb@sr.hp.com
Mark Ahrens
Hewlett Packard T&M AEO Email: mark_ahrens@hp.com
(800)-452-4844
"Ask me about Custom Test Solutions"
Mark Ahrens
US TMO Call Center
>Status: RO
>Hi
>connection.
>do transactions.
>thanks
>Stan Bischof
>stanb@sr.hp.com
Mark Ahrens
(800)-452-4844
connection.
do transactions.
thanks
Stan Bischof
stanb@sr.hp.com
