Hi Juan Carlos!
You are quite right, and I am well aware of it, but its the only kind
of "multitasking/ timeslicing" HP-vee can do in the 4.01 version.
Let's hope for some later improvements.
It's better than no timeslicing at all. I use interface event on the
RS232 to avoid to get timeout lockout for my other tasks. It works
OK for my application.
Bjorn Kristian Kleven
> Date: Tue, 12 Aug 1997 15:33:44 +0200
> To: hpvxd_xc%hpislsup.lvld.hp.com@hplb.hpl.hp.com
> From: Juan Carlos Martin <jcmar@mdr.indra-espacio.es>
> Subject: Re: Vrf:Formula vs. Function Name
> At 08:03 12/08/97 +0000, you wrote:
> >Hi Mike!
> >I have used call objects with function name input to create a
> >programable multitasking system in HP-vee, and it works well. I also
> >tried with the formula objects first, but they didn't work.
> >However I hope HP can make the formula objects with formula input
> >work with timeslicing in the future, because they are more useable
> >than a call function object.
> >Ericsson AS, Norway
> Bjorn,
> You are not using multitasking but multithreading. That is: your programs
> can execute several objects and functions with several objects at the same
> time, that is several threads at the same time. However, your programs
> cannot execute several VEE objects (like for example, if/then/else or
> formula or Direct I/O objects) at the same time. That is, you execute one
> step one each of these objects. Only some objects like delay are executed at
> the same time than the rest.
> >From my point of view, this is specially important for equipment
> communication objects. If you use a Direct I/O object, for example, you put
> a timeout of 2 minutes (and your equipment is not present), your program
> will be stopped 2 minutes in that object until timeout is expired. In a
> multitasking environment this is avoided: you are executing other objects at
> the same time you are communicating with the equipment.
> >>Is there a difference between the formula control input of a formula
> >>object
> >> and Function Name control input of a Call object?
> >> I am trying get time slicing working and it will not work if a formula
> >> control input of a formula object is used as stated on page A-6 of the
> >> Advanced Programming book, but maybe a call object with a function name
> >> input will work. Any thoughts?
> >> Mike Gustin
> >> mgustin@smsmfg.sme.siemens.com
> >______________________________
> >Bjoern Kristian Kleven
> >Ericsson AS
> >Norway
> >Mail: etobkle@eto.ericsson.se
> >Memo: ETO.ETOBKLE
> >Fax: +47 66 98 10 95
> >Phone: +47 66 84 16 03
> Mike,
> I have tested you information and you are right.
> However, I think it is not bad. I think that in some cases you specially
> want to execute a function and do not execute any other object until that
> function is finished. It is good to know that kind of behavior of
> Formula/Call objects. It would rather if formula objects could have a
> selection box (into properties) in order to choose the way the called
> function is executed: time slicing or not.
> Regards,
> ______________________________________________________
> Juan Carlos Martin
> E-mail : jcmar@mdr.indra-espacio.es
> Phone : 34-1-3963995
> Fax : 34-1-3963912
> Earth Stations Department
> INDRA ESPACIO / MADRID /SPAIN
Ericsson AS
Norway
Memo: ETO.ETOBKLE
> >Hi Mike!
> >Ericsson AS, Norway
> Bjorn,
> >>object
> >> Mike Gustin
> >Ericsson AS
> >Norway
> >Memo: ETO.ETOBKLE
> Mike,
> Regards,
> Juan Carlos Martin
> Fax : 34-1-3963912
Ericsson AS
Norway
Memo: ETO.ETOBKLE
Is there a difference between the formula control input of a formula object
Mike Gustin
