VRf-Datasets-Records
Question asked by VRFuser on Sep 8, 1997
send q VRf-Datasets-Records ww vrf rdm@granville.com
      website:  ftp://fcext3.external.hp.com/dist/mxd/index.html
to:   Roger Martin
date: Monday, 08 September 1997 1550 MDT
> From: "Roger D. Martin" <rdm@granville.com>
> To: "HP VEE User's Group" <hpvxd_xc@hpislsup.lvld.hp.com>
> I'm new to HP VEE 4.0 so hopefully there is a simple solution to my
> problem.
> I want to search a dataset and "grab" the most recently added 50 records
> within it.  Then I want to extract the values of ONE of the fields of
> all 50 records and compute the average value.
> I don't know what search specifier to use in the "From Data Set" box so
> that I will always get the last 50 records.  (The total number of
> records will continually increase.)  One of the fields will be a time
> stamp; perhaps there is some way to "grab" the 50 records with the
> "smallest" time stamp?
> Thanks for any help
> Roger Martin
> rmartin@granville.com
Sir:
Bruce Wenner had an elegant way to get the last 50 records.  Once you do
that, it is easy to get the average value of a field (named, say,
"datafield") with a Formula like:
       |         Formula          |
   --->| A | mean(A
  • .datafield) +-->
    If you have more questions, please let us know.
    [<>] regards -- gvg
  • Outcomes
