send q VRf-Positioning_Panels ww vrf Mike.Gagne@comdev.ca
website: ftp://fcext3.external.hp.com/dist/mxd/index.html
to: VRf-Mike Gagne
date: Wednesday, 10 September 1997 1700 MDT
> I've got a slight problem with the pop-up location of message boxes.
> I'm currently using HP-VEE v4.0 to run a HP-VEE program that
> was originally writtten with v3.21 (this is all under HP-UX v10.20).
> The problem is that all message boxes pop-up in the top-left portion
> of the screen, not centered. So far, I've tried the following with no
> success;
> 1- Running the program and centering the message boxes. After which I
> re-saved the program. After re-loading and running the program again
> most of the message boxes were still located in the top-left corner.
> 2- Deleting the message boxes, recreating them, re-saving,
> re-loading, and then running the program. I got the same results,
> top-left corner ...
> Is this a bug or am I doing something totally wrong ? Furthermore, is
> there a method by which I can specify the location of a message box ?
> Any help is much appreciated ...
> Regards
> Michel Gagne
> COM DEV Ltd
> Cambridge, Canada
> (519) 622-2300 x 575
> Mike.gagne@comdev.ca
Sir:
This is a bug. The trick is that even though you have a panel view in your
VEE development environment, positioning the pop-ups relative to that panel
view does no good.
You have to run your program, get the *execution window*, and then position
the pop ups. This will then lock the pop ups in place.
As an added confusion, Start buttons cause problems in getting things to
work properly. I suggest that you eliminate them from your program.
This should be fixed in the next release. If you have more questions, please
let us know.
[<>] regards -- gvg
to: VRf-Mike Gagne
> success;
> top-left corner ...
> Regards
> Michel Gagne
> COM DEV Ltd
> Cambridge, Canada
Sir:
view does no good.
let us know.
[<>] regards -- gvg
