VRf
I wrote and successfully executed a DLL using Borland 5.0 and VEE 3.2, but
when I ported it to another computer running VEE 4.01 I get the error
message when trying to import the library - "cannot execute <filename>". I
have VEE 3.2 running on a pentium PC and VEE 4.01 on another pentium PC
both using Windows 95. Am I missing a compiler switch or what do you think
the problem might be??? Any direction is helpful.
Thanks for the fast responses. Here is more information.
I used Borland to compile the DLL as 32 bit using DllEntryPoint(). When I
import the library from within VEE I set the path for the DLL and the *.h
in the inport library object. Any more ideas are appreciated.
Sandra Koppen
NASA LaRC
Hampton, VA
s.v.koppen@larc.nasa.gov
Sandra Koppen
NASA LaRC
Hampton, VA
