website: ftp://fcext3.external.hp.com/dist/mxd/index.html
to: VRf-Darcy ********
date: Wednesday, 17 September 1997 1343 MDT
> To: HP Vee Reflector List
> Can anyone provide any way of getting an HPIB board (HP 82335) to
> function under Windows NT 4.0.
Unambiguously NO. There's no software support for the 82335 on NT and, given
that NT is a real hard case about access to hardware through anything but
NT's approved I/O techniques, no way to improvise it, either.
> We have three of these boards and are
> moving our Engineering dept. over to NT 4.0 shortly. The documentation
> for HP Vee 4.0 states that we need to upgrade our boards to an HP 82341
> but no explanation is given as to why. I'm hoping someone has found a
> workaround to get the older boards to be recognized in NT 4.0. Any help
> would be appreciated.
> Thanks
> Darcy
> Darcy ********, Computer Systems Controller
> Racal Canada Inc., Vancouver BC.
> Internet: ********@racalcanada.com
> Ph: (604) 254-6411 Fax: (604) 254-2080
[<>] regards -- gvg
Subject: Re: Vrf:PCMCIA cards
To: stanb@hpnmrsb2.sr.hp.com (Stan Bischof)
Date: Thu, 18 Sep 97 9:53:10 MDT
> Both the National Instruments and INES cards work OK for many users around here in
> HP and Toshiba laptops of various flavors. The NI card is relatively difficult to
> install but is fine otherwise. The INES card installs easily but doesn't seem to
> show up in the instrument finder.
> I don't have any particular preference between the two.
> Also, so far as I know these are the only two alternatives.
Please note that MXD does not claim any support for the INES card. It may
work or may not.
[<>] regards -- gvg
> Thanks
> Darcy
[<>] regards -- gvg
work or may not.
[<>] regards -- gvg
function under Windows NT 4.0. We have three of these boards and are
Thanks
Darcy
