send q VRf-Meter_Bug ww vrf allan.strombert@ki.ericsson.se
to: Allan Strombert / VRf
date: Monday, 09 June 1997 1209 MDT
> To: Vee Reflector
> From: allan.strombert@ki.ericsson.se
> Subject: meter bug ?
> Platform: VEE 4.0, HP Vectra Pentium, WinNT 4.0
> Relax this is a kind bug if any.
> In Vee 4.0 do DISPLAY-INDICATOR-METER and settings of the input of RANGE 1.
> It seeems to me the MIN / MAX ought to be switched.
> Regards
> Allan
Sir:
What problem are you seeing? I checked your program and everything seems to
work as it should.
Note that (as mentioned in the Help file) MIN does not have to be less than
MAX and MAX doesn't have to be greater than MIN ... the two values may end up
reversed if you change those rules.
[<>] regards -- gvg
> To: Vee Reflector
> Regards
> Allan
Sir:
work as it should.
[<>] regards -- gvg
