VRf meter bug ?
Question asked by VRFuser on Jun 9, 1997
X-Sun-Data-Type: text
X-Sun-Data-Description: text
X-Sun-Data-Name: text
X-Sun-Charset: us-ascii
X-Sun-Content-Lines: 11
To:       Vee Reflector
Subject:  meter bug ?
Platform: VEE 4.0, HP Vectra Pentium, WinNT 4.0
Relax this is a kind bug if any.
In Vee 4.0 do DISPLAY-INDICATOR-METER and settings of the input of RANGE 1.
It seeems to me the MIN / MAX ought to be switched.
Regards
Allan
X-Sun-Data-Type: default
X-Sun-Data-Name: metdemo.vee
X-Sun-Content-Lines: 355
(saveFormat "2.3")
(date "Mon 09/Jun/1997 11:49:48 ")
(veerev "4.0")
(platform "PC")
(execMode fast)
(filterNAN 0)
(workspaceStackingOrder M)
(SaveCF no)
(device 0 ROOTCONTEXT
(properties
(trigMode deg)
(nextID 14)
(popupTitleText "Untitled")
(popupMoveable 1)
(deleteGlobals 0))
(deviceList
(device 0 METER
(properties
(range -1 1)
(redRange 0.778 -0.6960000000000001)
(yellowRange -0.462 0.52)
(greenRange -0.076 0.251))
(interface
(input 1
(name "Data")
(requires
(datatype Real)
(shape "Scalar"))
(lock name constraints))
(input 2
(type control)
(name "Range 1 Min")
(tag "Range 1 Min")
(requires
(datatype Real)
(shape "Scalar"))
(optional yes))
(input 3
(type control)
(name "Range 1 Max")
(tag "Range 1 Max")
(requires
(datatype Real)
(shape "Scalar"))
(optional yes))
(input 4
(type control)
(name "Range 2 Min")
(tag "Range 2 Min")
(requires
(datatype Real)
(shape "Scalar"))
(optional yes))
(input 5
(type control)
(name "Range 2 Max")
(tag "Range 2 Max")
(requires
(datatype Real)
(shape "Scalar"))
(optional yes))
(input 6
(type control)
(name "Range 3 Min")
(tag "Range 3 Min")
(requires
(datatype Real)
(shape "Scalar"))
(optional yes))
(input 7
(type control)
(name "Range 3 Max")
(tag "Range 3 Max")
(requires
(datatype Real)
(shape "Scalar"))
(optional yes))
(output 1
(type exception)
(name "Error")
(optional yes))))
(device 1 SLIDER
(properties
(name "Real Slider")
(range -1 1)
(detents 0.001))
(interface
(output 1
(name "Real")
(lock name constraints)))
(implementation
(value Real
(data  0.673))
(initValue Real
(data  0))))
(device 2 REPEATUNTILBREAK
(interface
(output 1
(name "Continuous")
(lock name constraints))))
(device 3 TEXTDISPLAY
(interface
(input 1
(name "Data"))))
(device 4 SLIDER
(properties
(name "MIN")
(range -1 1)
(detents 0.001))
(interface
(output 1
(name "Real")
(implementation
(value Real
(data  0.778))
(initValue Real
(data  0))))
(device 5 SLIDER
(properties
(name "MAX")
(range -1 1)
(detents 0.001))
(interface
(output 1
(name "Real")
(implementation
(value Real
(data  -0.6960000000000001))
(initValue Real
(data  0))))
(device 6 SLIDER
(properties
(name "MAX")
(range -1 1)
(detents 0.001))
(interface
(output 1
(name "Real")
(implementation
(value Real
(data  0.52))
(initValue Real
(data  0))))
(device 7 SLIDER
(properties
(name "MIN")
(range -1 1)
(detents 0.001))
(interface
(output 1
(name "Real")
(implementation
(value Real
(data  -0.462))
(initValue Real
(data  0))))
(device 8 SLIDER
(properties
(name "MIN")
(range -1 1)
(detents 0.001))
(interface
(output 1
(name "Real")
(implementation
(value Real
(data  -0.076))
(initValue Real
(data  0))))
(device 9 SLIDER
(properties
(name "MAX")
(range -1 1)
(detents 0.001))
(interface
(output 1
(name "Real")
(implementation
(value Real
(data  0.251))
(initValue Real
(data  0))))
(configuration
(connect D1:1 D0:1)
(connect D4:1 D0:2)
(connect D5:1 D0:3)
(connect D7:1 D0:4)
(connect D6:1 D0:5)
(connect D8:1 D0:6)
(connect D9:1 D0:7)
(connect D2:1 D1:0)
(connect D0:1 D3:1)
(connect D2:1 D4:0)
(connect D2:1 D5:0)
(connect D2:1 D6:0)
(connect D2:1 D7:0)
(connect D2:1 D8:0)
(connect D2:1 D9:0)))
(contextCarrier
(wndOrigin 2 2)
(wndState res)
(active detail)
(detail
(extent 1342 984)
(anchorPt -86 -94)
(configuration
(devCarrierFor 0
(active open)
(icon
(extent 40 16))
(open
(extent 404 245)
(layout horizontal)
(extratics)
(fastmode off))
(terminals on)
(pinCenter 655 260))
(devCarrierFor 1
(active open)
(icon)
(open
(extent 111 222)
(layout vertical)
(fastmode off)
(extratics))
(pinCenter 190 600))
(devCarrierFor 2
(active icon)
(icon
(extent 74 52)
(iconImage "loop.icn"))
(open)
(terminals on)
(pinCenter 190 250))
(devCarrierFor 3
(active open)
(icon)
(open
(extent 131 28))
(pinCenter 980 260))
(devCarrierFor 4
(active open)
(icon
(extent 27 0))
(open
(extent 111 222)
(layout vertical)
(fastmode off)
(extratics))
(bg "Light Warning Red")
(pinCenter 340 600))
(devCarrierFor 5
(active open)
(icon
(extent 32 0))
(open
(extent 111 222)
(layout vertical)
(fastmode off)
(extratics))
(pinCenter 950 600))
(devCarrierFor 6
(active open)
(icon
(extent 32 0))
(open
(extent 111 222)
(layout vertical)
(fastmode off)
(extratics))
(bg "Yellow")
(pinCenter 830 600))
(devCarrierFor 7
(active open)
(icon
(extent 27 0))
(open
(extent 111 222)
(layout vertical)
(fastmode off)
(extratics))
(bg "Yellow")
(pinCenter 470 600))
(devCarrierFor 8
(active open)
(icon
(extent 27 0))
(open
(extent 111 222)
(layout vertical)
(fastmode off)
(extratics))
(bg "Green")
(pinCenter 590 600))
(devCarrierFor 9
(active open)
(icon
(extent 32 0))
(open
(extent 111 222)
(layout vertical)
(fastmode off)
(extratics))
(bg "Green")
(pinCenter 710 600))
(connect D1:1 D0:1
(points 6 248 600 270 600 270 450 280 450 280 170 360 170))
(connect D4:1 D0:2
(points 6 398 600 410 600 410 590 260 590 260 200 360 200))
(connect D5:1 D0:3
(points 6 1008 600 1030 600 1030 100 340 100 340 230 360 230))
(connect D7:1 D0:4
(points 6 528 600 550 600 550 450 310 450 310 260 360 260))
(connect D6:1 D0:5
(points 6 888 600 910 600 910 410 320 410 320 290 360 290))
(connect D8:1 D0:6
(points 6 648 600 670 600 670 420 330 420 330 320 360 320))
(connect D9:1 D0:7
(points 6 768 600 790 600 790 430 340 430 340 350 360 350))
(connect D2:1 D1:0
(points 5 229 250 250 250 250 300 190 300 190 468))
(connect D0:1 D3:1
(points 2 899 260 912 260))
(connect D2:1 D4:0
(points 5 229 250 270 250 270 440 340 440 340 468))
(connect D2:1 D5:0
(points 5 229 250 270 250 270 440 950 440 950 468))
(connect D2:1 D6:0
(points 5 229 250 270 250 270 440 830 440 830 468))
(connect D2:1 D7:0
(points 5 229 250 270 250 270 440 470 440 470 468))
(connect D2:1 D8:0
(points 5 229 250 270 250 270 440 590 440 590 468))
(connect D2:1 D9:0
(points 5 229 250 270 250 270 440 710 440 710 468)))
(stackingOrder 7 4 8 9 6 5 0 2 1 3))
(numberFormats
(realFormat standard)
(realSigDigits 4)
(realRadixSpec 4)
(integerBase decimal))))
