VRf-Serial_Mux
Question asked by VRFuser on Jun 15, 1997
We are doing this using a Central Data SCSI terminal server. It gives us
8 serial ports via the SCSI bus. Our machine is an HP 745I running
HP UX 9.x.
We wrote a shared library to allow VEE to control the termio settings
although
you can set them from the O.S. and just use VEE for I/O. Our library also
handles some special communications protocols which were a bit slow for
VEE to handle ( e.g. computing CRCs ).
The following man pages will be very useful:
termiox (7), termio (7), open (2), ioctl (5) & (2), modem (7), write (2),
read (2),
tccontrol (3C), mknod (1M) [this creates the /dev/serialXX device I/O
files,
close (2), cfspeed (3C), tcattribute (3C)
The following system include files are also very useful:
termios.h, termio.h, modem.h, ioctl.h, stat,h, mknod.h, errno.h
I imagine this would work just about the same for an 8-port EISA RS-232
multiplexer.
Regards
Rob Marquardt
Rockwell Automation / Allen-Bradley
Milwaukee, Wisconsin, USA
> To: hpvxd_xc@hpislsup.lvld.hp.com
> From: Juan Vera <jvera@mdr.indra-espacio.es>
> Subject: VRf-RS-232 MUX on HP-UX platform
> Hi VEE users:
> Does anybody know if VEE is able to manage an 8-port EISA RS-232
multiplexer
> for HP-UX platform (e.g. C180 WS)?
> Maybe esaier if using DT VEE ?
> Need advice.
> Thanks in advance.
> | Juan Vera     |
> | E-mail: jvera@mdr.indra-espacio.es |
> | Phone: 34-1-3963986   |
> | Fax:  34-1-3963912  |
> | Earth Stations Department   |
> | INDRA ESPACIO S.A.    |
> | Mar Egeo 4, Pol. Ind. 1   |
> | San Fernando de Henares   |
> | 28850 MADRID    |
> | SPAIN     |
