VRf-VEE_IC_Bug
Question asked by VRFuser on Jun 16, 1997
[VEE] VEEBUG -- ID Compiler Won't Work On WinNT
* That's right -- if you try to use Instrument Manager to load a .ID file
(which means that it should be automatically compiled), all you get is
a parse error.
However, if you go to a DOS window and specify the HPIDC.EXE and the driver
directly within the proper directories:
P
   ..hpidc.exe hp5313x.id  p
-- it compiles fine.  So we have a workaround ... sounds like a path
problem.
[<>] gvg / 16 jun 97
