send q VRf-Timestamp ww vrf sra@nera.no
to: VRf-Steinar Rafaelsen
date: Tuesday, 24 June 1997 0858 MDT
> To: hpvxd_xc@hpislsup.lvld.hp.com
> Date: Tue, 24 Jun 1997 10:14:28 +0100
> Subject: VRF time stamp format compatibility betwwen VEE 3.12 and VEE 4.0
> To (mostly) Greg!
> Question:
> Is the VEE time stamp format saved into a "DATA SET" file by VEE 3.12,
> recovered correctly when read by "FROM DATA SET" in a VEE 4.0 program??.
> I ask this because I am getting some weird results, and need to know is
> this is a potential problem.
> Regards
> Steinar Rafaelsen
> Nera ASA Telecommunications
> Norway
Sir:
I wrote a short program under VEE 3.12 to create a dataset with four records.
The first field of the record contained an integer, the second contained the
value of "now()". I wrote out the dataset, then wrote a simple program under
VEE 4.01 to read back the records.
I saw no problems (and no bug resembling this was fixed from VEE 4.0). Do
you have any details?
Please stay in touch.
[<>] regards -- gvg
> To (mostly) Greg!
> Question:
> Regards
> Steinar Rafaelsen
> Norway
Sir:
[<>] regards -- gvg
