send q HOME_Variable ww bischof_s
gvg@lvld.hp.com / 970-679-2305 / FAX 970-679-5971
website: ftp://fcext3.external.hp.com/dist/mxd/index.html
to: Stan Bischof
date: Monday, 28 July 1997 1553 MDT
> I just installed an application on my computer totally unrelated to VEE
> and when I went into VEE found that my IO Configuration was gone!
> I poked around and found that the vee.io file was still intact in the
> install directory but for some reason was not being read in by VEE.
> Strange to say the least.
> After some experimentation ( I went into vee, created a new IO config
> and saved it. Then went to my explorer and did a "find" looking
> for vee.io) I found that VEE is now looking in the new application's directory!
> Afetr a little more poking I found that the new application is setting
> an environment variable called HOME. And it appears that if HOME is set
> then VEE looks in the HOME directory for vee.io instead of it's own
> install directory.
> VEE _doesn't_ appear to use HOME for anything else, like default
> directory, startup directory, looking for menu files, etc.
> Any way around this?
> Is this intended behavior or a bug?
Intended behavior ... to allow different users to have different VEE.IO
files. Mostly applicable to WinNT and HP-UX where multiple users is a normal
procedure.
> Stan Bischof
> stanb@sr.hp.com
[<>] regards -- gvg
to: Stan Bischof
> install directory.
procedure.
> Stan Bischof
> stanb@sr.hp.com
[<>] regards -- gvg
