Hi VRf,
I've got a slight problem with the pop-up location of message boxes.
I'm currently using HP-VEE v4.0 to run a HP-VEE program that
was originally writtten with v3.21 (this is all under HP-UX v10.20).
The problem is that all message boxes pop-up in the top-left portion
of the screen, not centered. So far, I've tried the following with no
success;
1- Running the program and centering the message boxes. After which I
re-saved the program. After re-loading and running the program again
most of the message boxes were still located in the top-left corner.
2- Deleting the message boxes, recreating them, re-saving,
re-loading, and then running the program. I got the same results,
top-left corner ...
Is this a bug or am I doing something totally wrong ? Furthermore, is
there a method by which I can specify the location of a message box ?
Any help is much appreciated ...
Regards
Michel Gagne
COM DEV Ltd
Cambridge, Canada
(519) 622-2300 x 575
Mike.gagne@comdev.ca
success;
top-left corner ...
Regards
Michel Gagne
COM DEV Ltd
Cambridge, Canada
